- racing transmission
- Help: Clutch Issue
- has anyone.
- Spec stage II+
- need help removing trans
- For those with Excedy Stg3 Clutch
- Best clutch for f23 and testimonials
- Transmission Failures/Problems 2.2/2.4/2.0
- this clutch work?
- The right clutch for harrop blower
- Correct B&M Shift+??
- Trans Fluid???????
- power shifting and syncronizing rings
- 2.4l g5 gt tranny questions.
- 2008 cobalt owners
- B&M shiftplus
- SS/SC Synth Transmission Oil: Which is best?
- anyone have the wepon R torque damper?
- People who have the Centerforce
- Transmission Rebuild
- 2nd gear synchro?
- Built Shep Trans Interest Thread
- Shift+ Warrenty?
- Does clutch pedal need adjusting?
- Full syn. tranny fluid?
- well....I broke something last night....
- spec stage 2+
- worst night this year so far
- The "Broken F35 Transmission" thread
- Problems with clutch install
- Which Clutch
- 400 miles/tank Trip to FL
- To Pulstar spark plug or say no?
- What kind of Blood Runs in your ride?
- Tranny Tools
- Tranny question NEED HELP
- B&M Shiftplus kit
- F40 swap
- any s/c guys need a new motor...EBAY
- What's the best short throw out there?
- Shifter to Tranny
- gears for 2.4 guys
- B&M Shiftplus Questions
- Cryo Frozen Tranny
- Faulty clutch cyl from factory???
- repairing of an axle
- conversion from auto to manual
- Installing B&M Supercool Trans Cooler
- I got my Centerforce clutch installed
- think i broke my axle
- Ingalls ETD acting a bit funny
- Removing Axle/Differential Seal on F23
- shiftplus
- exedy hypersingle installed, p0300?
- are they the same
- Short Shifter
- Popped my trans in 06 SS
- what would you suggest??
- ***Clutch Repaired: UNDER WARRANTY***
- clutch smoked in cruise control
- Broke my tranny, any good replacements/upgrades?
- axles coming for the 2.2/2.4
- Alright everyone i need some advice please
- short shifter question
- Exedy Hyper Single Clutch question
- Wheel Bearings
- Going into Reverse?
- Shift Light.
- Fidanza flywheel/clutch fitments
- LSJ pressure plate adjustment?
- clutch probelm?
- B&M Shift Plus
- B&M shift plus
- B&M Shift+
- exhaust system...
- new clutch
- Quick clutch question
- Installed my Hurst shifter today. (pics)
- Tranny fill plug size on the SS/SC
- Why Do the Automatics have...
- tranny noises
- Transmission Bushings?
- roll pin issue
- Best flywheel
- Best clutch to get!
- Fryed clutch!
- automatic to manual....2.2L sedan
- Tranny Help
- B&M Shift Plus
- One more question for guys with the ebay shifter
- weird pop and limp node MAF
- Short throw shifter solutions?
- LSD vs Non-LSD?
- TWM shifter
- lost 2nd gear?
- Cobalt Spec 3+ Clutch
- Info Trouble!!!!
- 2.4 Auto Shift points ?
- 2.2 short shifter
- Helppppp!!!!!! Need To Know!!!!!!!!
- I need to know
- Short Shifter Question
- ACT Clutch Release Date
- Good Supporting Mods?
- B&M shiftplus
- Leaking Tranny Fluid from the axle
- how can I tell if it has a LSD
- 2.2 4t45 axles
- not smooth going into gear
- 4t45
- Billet Trany Case!!
- tranny ?
- 'I' vs. 'D' Gear
- Spec Stage 2+ and Fidanza Flywheel
- 6 SPEED trans???
- do i have the wrong tranny mounts please help!!!
- b-woody traction bars??
- Breaking in new clutch??
- Are there any how to's for installing poly trans mount insert bushings?
- Clutch/Flywheel Suggestions
- Short Throws!!??
- Axle shaft seal part number
- ss sc shifter works on ls
- Problem with second gear
- Aftermarket Lsd
- Linkage Roll pin
- New GM SI Bulletin
- no pedal pressure
- Tranmission chatter?
- 2.2 shifter
- winding noise while accelerating
- 2.4 tranny
- My baby is gunna get surgery!!
- The best Clutch for the money !
- Loose Shifting
- Tranny mounts
- Very odd clutch problem , need some useful input
- Anyone else have gear whine in their f35 diff's
- b&m or hurst
- uh... spline count? rotor dimensions? ABS?
- Good News!!!
- No clutch alignment tool??? Dont worry I got the solution!!!!!
- Does Anybody Problems W/ Axel Seals?
- Clutch and flywheel help
- 04 redline axle swap
- I wanna put a lsd in my non lsd tranny..question
- Torque Specs for Upper engine mount/ transmission mounts.
- Exedy OEM CLUTCH
- aftermarket clutch recomendations
- Need some help from NC people
- Spec stage 2 or stage 2+?
- Clutch Install Price
- Spec Clutch Problems
- Short Shifter Question!
- Benefits of double clutching??
- ? Shift w/o clutch
- Step to a Motor Removal
- What do you think
- stock clutch problems and engine torque dampner
- Spec Stage 2+ clutch w/Stock Flywheel?
- Hurst feels sloppy...
- In need of new Clutch.. finding one is half the battle
- after how many miles
- Tranny balt??????
- Clutch Questions: Input Needed...
- Clutch problems maybe?
- awesome dealer
- 3rd Gear Grind
- Lightweight Pulley
- Just Orded ZZP Mounts
- how good can this be?
- lost 2nd 4th an Reverse!!
- whole new drivetrain
- Which tranny cooler is best bang for the buck
- Axles
- trans mounts
- Got in a small accident (with pics) need help diagnosing what needs fixed
- Clutch
- has anyone swaped in an f40 trans
- transmission housing ?
- Clutch Help!
- HELP!!!!!!!!! tranny problem
- What are the stock axels rated for
- Got Trans Out Again
- b&m shift plus
- question about clutch install
- Hurst STS or B&M STS
- F35 replacement options
- shift knob replacement
- Best Clutch??
- Replacing the throw out bearing
- 2.0 LSJ Oil Filter Change.
- Help ASAP!!!
- new brand of clutch coming in june :)
- New clutch suggestions...
- Does anyone know??
- found this on ebay.
- Sooo ummm yeah...
- Shifter
- Lsd $ Wtf
- why so much slop in the shifter? bc of cable?
- Automatic B&m Shift Plus
- Clutch Problems
- MU3 Fluid
- Best oil filter?
- the part from H***
- CED trans
- Tranny whine and shifter block... sweet
- clutch options for me
- Installed Intense Poly Tranny Mounts Please Read!!
- noise from engine.
- Stock part numbers
- Clutch Masters Decision
- Drain plug
- F23 final drive ratio..
- New Clutch
- Phantom Grip ?
- OEM SS Clutch
- Brief auto to manual question
- Ordered myself an Ingalls Stiffy
- Questions about manual transmissions
- Noob Q!
- B&M Racing Shift Plus
- How do you guys shift from 1-2 when driving hard?
- Clutch Problems???
- Anyone Have any Feedback on The Quaife 6 Speed Gearkit?
- which side pulls us
- stg 2 axels
- Hurst S S problem
- Crunching noise shifting into 4th
- diffrent fluid to stop clutch slip?
- got some questions
- Anyone Have Powersteering Go Out?
- a lil grinding
- Can I buy just 1 axle?
- Axle disassembly help
- Gears....????
- b&m shift plus
- Money To Spend
- Clutch Pedal
- Short Throw question?
- B&M Short Throw problem?!?!
- TWM shifter for 2.2L
- Cosmo Short Throw shifter Question
- Vibrating Clutch Pedal
- will this shifter work??
- How many miles do you hae on your TurboTechRacing Motor Mount & Prothane Transmission
- Clutch
- TurboTechRacing Motor Mount & Prothane Transmission Mounts( 56k users beware)
