- Dyno
- Put in New Clutch, Having Problems
- Hurst Shifter Reverse lockout problem?
- Help removing shifter cable link
- People who are thinking or have a SPEC Clutch READ THIS!!!!!
- solid trans mount need help????
- Shift Linkage connection
- what gearing does the ss/sc have
- Opinon on the spec stage 2+ clutch
- Help Axle Shaft Snapped
- Can't shift hard into 4th...
- Is this good clutch to buy
- So i just bought a Bully Stage 4 clutch... Throw out bearing QUESTION
- RPM Problems!!!
- Tranny Mount Vibration
- Quick need a tech specialist
- SS/SC Shifter Modification?
- tranny took a lot of oil
- Transmission Teardown/Reassembly
- Bushing press?? is this what i need?
- New Pclear Short Shifter...
- Exedy Clutch Upgrade
- Light-weight flywheel information
- tranny mount part number?
- ss/sc tranny fluid?
- Need Help!!
- Transmission mount inserts
- 05 ss not lsd
- Please Help ( New Clutch Slipping )
- engine swap
- hold on!
- Looking for new or used trans for my SS/SC
- Uncool, tranny drain plug stripped
- Axle Help Quick!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Exedy Clutch Torque Rating?!?
- Nonsense with the tranny
- short shifter top speed????
- GM won't replace my trans if abused.
- Transmission Cooler
- Automatic Transmission Mounts
- Shifter Question??
- 2.2 Auto Driving style.
- Stock Clutch Died
- Will it work?
- Aftermarket clutch and warranty.......?
- How strong are the Ecotec Engine?
- clutch broke!!!
- clutch poll
- best clutch on the market
- Driveshaft Shop Stage 2 Axle Prices?
- trans mounts w/ least vibrations????
- P0741, My girls car
- intsalling Hurst shifter
- Best Clutch for my setup?
- When do cobalt SS trannys explode?
- clunky 5 speed
- Torque damper source of slip?
- Educate me on Kevlar or Ceramic clutches
- Shift kit
- sunfire transmission help
- wheel hop
- clutch slip?
- My tranny broken???
- used clutch + flywheel
- manual trans fluid
- What type of tranny does the SS/SC have?
- clutch review thread
- Spec clutch questions
- Grind in 2nd gear
- Exedy Clutch installed (a few Pic)
- Downshift or neutral??
- Question w/ Flowmaster..
- Exedy Clutch
- Regarding Malibu Maxx's "4-SPEED AUTO TRANSMISSION W/ TAP-UP/TAP-DOWN"
- Dont know what I broke, but I know I broke something
- Tranny Fluid puddle under SS/SC
- NO LSD! Need some help!
- 04 cavie shifter
- auto tranny mount bushing
- Exedy Twin-disk clutch..
- possible throwout bearing/slave issues ....please help
- Tranny Problem??
- auto to 5spd swap
- Gm Lsd???
- Royal Purple ATF and Syncromax
- What clutches do people have???
- Auto transmission fluid
- Bully Clutch Questions Answered!!!
- vibrant exhaust on 04 redline fit 07 balt?
- cluthc break in time 1k, 2k, 3k?
- Anyone having a problem with their Bully clutch?
- ZZP billet rear tranny mount ???
- too much power... slipping clutch??
- what clutch/flywheel combo...need help fast
- ACT Clutch Kit
- Is there a way?
- Final Drive Ratio
- Shifting in the SS/SC?
- Axles & Slicks
- Smaller pulley?
- LSD installation?
- Wheel Stud Problems
- Clutch Problem
- Idiot Reverse
- Need help on choosing Clutch and Flywheel for 2.2!!
- Posi
- Auto Trans Problems
- Anyone have.....
- no reverse after swap
- Is Royal Purple worth it??
- Cpp Prototype Auto Trany Front Poly Mount
- Catback Exhaust System.
- frustrating!
- Bully Clutch Results?
- Mobil 1 Oil
- Got my clutch warrantied....
- Tranny Number Two GONE!
- help with the knob.. searched everything already
- HElp!! Wierd noise and clunking when putting into 1st gear
- Removing 2006 Shift Knob
- WTB Transmission.
- Tranny mount quick fix
- Bully Clutch?????
- Twm Short Throw????
- Quafie ATB Diff. LSD
- 1999 Saab F35 Quaife LSD install
- cross drilled rotors
- Driver side motor mount
- trans gear ratios ?
- Used Trans w/ LSD???
- OK quick Question!
- need clutch help please
- Clutch smelled
- Hurst Question
- I need flywheel machining specs...
- Urgent Help Please!!!!!
- ? about tranny.(not Cobalt)
- 8.1 hours to do a clutch on a 2.0 SS/SC?
- Hurst Knob
- Wanna body slam my tranny..
- worn out clutch
- Yet another screwed clutch...
- sliping clutch
- Buying Hurst shifter
- kind of a stupid clutch question...
- installing shift how do i disconnect the shifter cables
- Noob clutch question
- Final drive gears wanted
- New Short Shifter Ark For the LSJ 2.0
- Friggin clutch!
- any 2.4's running aftermarket clutch/flywheel?
- Stock Shifter Real Loose
- Bwoody Traction bars Click/Clank/Tick after install.
- Stage Kits
- LSD Install?
- Check/Fill plug 2.0 SS/Sc
- Poly Trans mounts?
- which to BUY HURST OR B&M
- What went wrong here ?.........
- Trans Go
- Hurst Shifter Orders Shipping From Gravana
- B&M STS Feedback
- Auto tranny noise
- Torn Tranny Mount
- parts
- How do you remove shift cables from trans?
- wheel hop
- Bully Stage 4 full ceramic is in!!!
- blown tranny
- Safe clutch and flywheel for gm stg2
- New Addition To The Car
- Fluid for the SS/SC Tranny
- What Type Of Clutch??
- Just Installed!!!
- Quaife 6-Speed Conversion for FGP F35 5-Speed Manual Transmission!
- Another clutch thread.. Free dealer install
- Anyone have Spec stage 4?
- Tranny Problem
- Upgraded steering knuckles...ect...
- missed 3rd gear.
- mounts
- CPP Trany Mounts
- Fx 300
- axles limits
- F35 Tranny onto my 2.2
- Heres an idea for GM
- Spec stage 1
- 2nd Gear???
- Stick a FORK in my Tranny b/c its DONE!!
- Slave cylinder chirp/squeal again...
- TNT now offers TWM Short Shifters for the 2.4!
- TNT now offers TWM short shifters for the 2.2L Cobalt!
- Any Bully clutch reviews yet?
- Upgrading Axles
- Need some opinions
- Clutch help
- How fast in first gear
- 4 Puck or 6 Puck?
- Hurst shifter question
- Question about stock LSD
- Clutch Replacement
- need new clutch
- How do you know if the axles are bad?
- B&M/Hurst Shifters.
- Is anyone talking to....about...
- Drivetrain Installation Progress On Jackstands
- What causes wheel hop?
- 2.2 tranny?
- Weapon-R or Ingalls ETD??
- Trans dissasembly help!
- Motor Mounts
- LS Popping out of 2nd
- How high????
- LSD whine...loud!
- its flowing on the inside
- Grinding noise...
- Does The 07 come with lsd.
- repost maybe?
- Just got off phone w GM parts Dept
- Got my hurst w/no instructions!
- The Hurst shifter
- Exedy Clutch
- Can a 2.2 automatic bolt up to a 2.0 engine?
- 2.0 engine mounted up to a 2.2 trans can it be done?
- Quaife LSD
- I'll be back in business soon! Woot!
- bully clutch's sounds good but who has used one yet?
- Are the Saturn Ion Redline LSD trans indentical to the G85 Cobalt trans?
- Flywheel
- slave cylinder
- Spec clutch ratings
- Gear set in the G85 tranny and regular MU3 tranny ???
- ZEX plugs 82003-4
- Hurst or B&M
- I Need A Stock Axle
- hurst shifter install questions
- 3rd Gear Gone!
- Automatic to Manual
- B&M Buys Hurst Shifters?
- What aftermarket clutches are you all using?
- 8 bolt Flexplate?
- Exedy Is Here!
- Short Shifter...
- Spec stage 3+ and Fidanza flywheel question
- how do u know???
- Prothane making motor/trans mounts?
- What all can you do to the Auto Tranny?
- What exhaust is this??
- Clutch??
