- Clutch issues... fix TBD....
- had slipping clutch serviced......
- Ingalls x 2 - upper/lower ?
- Clutch Noise
- Anyone have a aftermarket clutch on their 2.4L?
- Where is the best place to buy ingalls dampener in Canada ?????
- Pleas every one on this site with an SS S/C READ AND VOTE!
- Ingalls Noise Fix
- Clutch Slipping from 1-2
- Looking for shop to install CAB's....
- Drive Shaft Sheered
- Quick Favor Please!
- SS/SC Exhaust and SS 2.4 Exhaust the same?
- Any updated news on the Hurst shifter? Vendors?
- Stock Clutch Slipping
- Good flywheel information...
- this has to be a misprint!
- for those with aftermarket clutches and stock flywheels..
- For The Vendors
- how do you adjust Ingalls Engine Damper
- Short Shifter People.. Are they worth it?
- Great Deal?-Fidanza Flywheel
- Why do I still have wheelhop?
- Kinda confused ... wheel hop issue.
- Does the LSD make a difference in the amount of HP and Torque?
- Time to TORQUE FORWARD!!!!!!!!!!!!!!!
- Clutch Masters Stage 3
- Still getting wheel hop!!!!!
- New Vendor Coming Shortly
- Buzzing sound coming from trans after clutch/flywheel instal
- Grinding putting it in reverse.
- Good and Bad news with Clutch/Flywheel installation
- poly-filled front tranny mount - poly split....
- installation of clutch/flywheel...
- WRX/STI/SRT-4 Transmissions
- ClutchMasters
- Clutch Question
- So i tried moving in third gear...
- factory clutch pics
- Shifting and SC wine...
- royal purple
- Ingalls Torque Brace install ???'s
- B&M Short Shifter
- poly engine mount
- I bet you have never been asked this before!
- ouch! my axel hurts
- Clutch Installation Questions
- question on g85
- suspension ideas??
- Banging noise while shifting
- Once again, GM's quality at it's finest...pics inside.
- Short shifter install? (b&m)
- Ingalls torque brace WORKS !!
- torque converter
- can i drop the car with 235's?
- Sheered the piece of $#!~ transmission mount off...
- Shifting Habits
- Auto tranny fluid
- Weekend Special @ TTR Fidanza
- Quaife LSD buying INFO!!!!!!
- spec 3+ and fidanza flywheel install
- more pulley sorry
- pulleys
- 2.4 clutch
- One of a kind clutch for the ss/sc
- !! Anyone With Clutch Issues Read This !!
- Stock intake hose
- tranny going out or do i just need fluid change?
- Any clutch ideas?
- Stock Clutch Adjustment?
- Which clutch has had best performance?
- warranty question
- Where to get Clutch alignment tool?
- Aftermarket Mount pressure limits?
- Shifter pops out of gear in 2nd
- Anyone gotten the new Hurst shifter??
- Lsd
- Question....*confused*
- Slippage
- I think I fried my clutch today-no more dyno or 1/4 baseline's?
- Catch Can
- 2006 SS Supercharger Clutch Question/Upgrade
- centerforce
- who makes them
- corsa sport exhaust
- lsd=confused
- 2.2 and 2.4 owners
- short throw shifter
- My Clutch = SOB
- On Order.
- dual exhaust setup
- Who would buy this?
- tranny question?
- New Dampner On The Market
- Flywheel Replacement
- Looking to buy, have clutch questions
- This might be a nice 6 speed
- the g85
- shifting question...
- Clutch Sucks
- pedals
- Clutch Pedal squeeks
- Synthetic trans oil
- What did you pay 4 new clutch?
- Problem with B&M shifter
- Hurst or B&M
- Trans Fluid Change
- If you have replaced your tranny/motor mount...
- aftermarket flywheel chatter?
- Info for clutch swap!!!!
- is g85 really worth it??
- Help! Stg.2 clutch slipped..
- LSD... Need help from vendors.
- fell of the shifter
- Where did you get your new clutch at???
- Shifting Question
- quaife install for the 2.2L
- Question on LSD
- 2.2ls
- Pulley Question
- Replacing stock clutch
- Trans Blows Agen!!!!!!
- Help me clutch question
- just wondering....
- New ZZP Poly Tranny Mounts
- launching the automatic with no T/C in regular Drive
- Doesn't Sound Good
- Anybody with a blown factory clutch?
- Spec or Exedy
- installing engine temp gauge in A pillar
- GMPP to address wheel-hop?
- Install Spec clutch?
- ZZPerformance POLY Motor Mounts
- clutch up and pushed out of gear?
- Installing st2 clutch/flywheel?
- first O6 to blow trans
- what kind of clutch?
- Ordered Hurst shifter and torque braces!!!
- Not sure if a problem or not....
- clutch question?
- b&m ratchet shifter
- Short shifters for 2.2l maybe 2.4l?
- Stock clutch sucks balls
- Royal Purple in Getrag 287 (5spd in ALL '06 Cobalts)
- Problem
- pics of our spec clutch
- performance difference
- BIG Problems
- who has swapped their clutches?
- Tranny mount UPGRADE
- B&M ratchet shifter for auto?
- Auto Trans Interceptor
- auto to manual? whoa.
- Clutch Engage Point
- replacement tranny fluid
- How bad is stalling?
- Light Weight Flywheel
- Hurst Shifter/ RK Sport
- Hurst Shifter for SS
- Reverse and first in a stick ?
- Weapon*R vs Ironman/GoofyGuy
- cobalt - model of the auto tranny?
- Aftermarket Clutch??
- OE solid filled motor mounts
- LSD from Quaife
- problem with chirping in going into 2nd.
- how much power can the 5 speed handle
- winter steel wheel for the cobalt SS 2.0
- Clutch Info for a newb
- Need Manual Driving Help..
- Multiple Tranny Problems
- no engine noise, no revs on tach, no good
- Twin loop Muffler
- IAT Sensor Trick?
- power steering problem
- Clutch Sticking
- A Kid and his Clutch problems
- clicking while turning
- So am I the only one that got a flawed B&M shifter
- Tranny Problems
- rev limmiter
- Friggin' Shifter Install
- Getting my SS into reverse
- 5 or 6 Speed
- 3rd gear blown already!?
- How much HP can Auto Tranny hold?
- Problem with the tranny need your info PLEASE!!!!!
- 2006 cobalt ss auto tranny
- ss s\c drilled and slotted rotor
- Transmission swaps
- SS tranny Oil.
- Catalytic Converter Issues??
- Reviews On Shifting Smooth??
- Learning to drive standard lol!
- Quaife LSD install after the warranty runs out or before
- Pirelli PZero rosso question
- Even Stranger Shifter Problem!
- Stalled And Died 2005 LS Sport Coupe?
- 2006 ss auto gear selections
- Shifter loose all of a sudden?
- My Busted Up Driveshaft - Pictures
- Hydraulic clutch hose kinked. Cobalt towed.
- Does a non-perf. package SS have a LSD or posi?
- smelly Clutch!
- A/t Shift Lever Binding!!
- Does anyone know the part number for LSD?
- Gearing
- Clutch Throw...
- Recall on SS Tranny ? ? ?
- Blew Drive Shaft
- Clicking in 1st and 2nd
- Tranny?
- clutch slipping
- Please help me! Problem with my SS!!!!!!!!
- Shifter
- Does The Lsd Mean That Much??
- Coolant Temps
- Check Engine Light on
- ? Play in SS shifter ?
- SS S/C - Strange shifting behavior
- does the LS only come with Auto trans
- Removing the stock shift knob on a SS
- Dealer-installed Quaife LSD
- Trans Swap
- question on auto tranny
- Anyone bought a SS S/C with LSD yet??
- Clutch
- Auto better than manual
- ENGINE/Trans Origin and design??
- Any one have transmission problems?
- Quaife LSD
- Oil Changes
- shiftin in racing
- Shifter Help
- Info about Domestic Performance
- B&M short shifter for the Cobalt!
- Shifting into reverse
- MK1 short shifter for IONs...inside
- just got a reply back from ACT
- Tranny choices and opinions
- Automatic OD Lockout
- New section
- With this new sport package thread started...whats the word with LSD being standard?
- 5 Speed Auto and SS 2.4
- The definitive word on the LSD
- Automatic?
