View Full Version : Drivetrain
Pages :
2]
13
14
- 1st through 4th gears won't engage.
- What is this? Pic included
- F40 6 speed install
- Clutch help
- Fidanza flywheel anygood
- 05 cobalt ss/tc
- Clutch Prep
- Need clutch kit input...Clutch masters or Centerforce?
- Pedal Losing pressure
- Holiday Deals: Reasons to Buy ZZP Trans Mounts?
- KY Performance F35 Twin Disc Released!
- LuK Flywheel Updates
- 35/35 sprocket drive chain set in high revving 4T45-E build?
- F35 transmission repair
- flywheel bolt specs
- Exedy OE Clutch Rating
- Clutch Master Cylinder Replacement
- Clutch Pedal Play
- Flywheel Bolts
- F35 Clutch alignment tool 3d file
- LSJ clutch on L61/LE5 flywheel
- Stuck in gear after clutch install
- Humming....bearing or cv joint
- Weird noise coming from axle
- Clutch won't hold pressure long after bleeding
- F35 tranny question
- Cobalt SS/SC head and cams
- Clutch bleeding problems
- Blown Transmission
- Auto Trans Issues Cobalt LT
- Blue Shifter Piece under Shifter spring that "locks" out reverse
- Ottp STS
- ZZP TOB Spacer
- Engine support when removing engine cradle
- Clunking noise when shifting up.
- Stock shifter adjustment? New shifter?
- Looking for clutch LNF 315 whl tq
- 05 Cobalt SS transmission swap
- 2nd Gear Grind
- Transmission to Axle Part
- KY stage 2 clutch kit for F23
- Axle shaking engine
- Cv axle help
- grinding reverse
- cv axle thump
- No 4th after 3rd gear pull?
- Zzp Throw out bearing spacer
- Tranny help!
- Clunking coming from inside transmission
- Roll pin problem need help
- Performance Autowerks vs ZZP built transmission
- Popping/clunking noise
- LNF sometimes grinding 2nd and 4th
- LNF - Third Gear High RPM
- cv joint boot for GM upraded wheel hop axle
- Helpppppp!!!!!!!!
- Oil and clutch questions
- Weird shifting/clutch
- F35 MU3 shift lever differences
- KY Stage 3 PLUS anyone?
- Info for taking apart an F35 trans
- Moving clutch and fw to new motor
- GmPp clutch still available for lnf Balts?
- Clutch over extension?
- Drivetran clunking noise..
- So i feel like i got swindled out of an extra 100$ From the Dealer.
- Performance AutoWerks Bleedable LNF clutch slave cylinder
- Got to change the axles..
- Transmission rebuild parts needed?
- Lsj replacement flywheel
- Clutch wont bleed? maybe?? or somethings wrong...
- Ottp STS help
- Shifter Cables
- Watch me break my clutch in this sweet video
- Axle or wheel bearing? Or something else
- LSJ rear axle beam in LNF??
- 3rd Slave cylinder in 1 year!
- 2009 cobalt ss 78k Miles rear tires worn from inside
- F35 Transmission Fluid Never Needs Changed Per GM!?
- Short Throw Shifter - which is best?
- Clutch Question/Problems
- Modified Gear Box / Shift Pattern
- Drivetrain slop in sstc
- Clutch question
- Hard Shifting
- Clutch issues!!!
- ky stg 3 clutch issue
- T/c and abs warning lights
- Transmission Mount Bolts
- Part number request. Clutch safety switch.
- Any how to for replacing shift cables.
- doing small build need input
- ottp stg1 rotated mounts? what are the benefits?
- What is this spacer for?
- ZZP is selling F40 kit again.
- Time for new shift cables?
- What is this...?
- reverse lights not being activated
- 2009 won't shift to reverse or 5th when cold engine not running
- Clutch questions 09 SS/TC
- HELP PLEASE!! need a gear for MU3
- Clutch is really high
- Automatic transmission difference
- Stick won't move out of reverse!
- SS/TC Front Pads & Rotors
- Abs module
- Cast aluminum welding
- Cobalt SS/TC Shifter, GM Microfiche Help
- New to me SS with clutch issues
- mu3 parts availability
- New clutch, round two!
- P0010 - CEL on and off
- Car does not shift into 3rd or 4th gear
- Pontiac G5 Clutch
- Clutch experts needed
- Oil in Intake
- Final Drive Question
- New product release!
- Transmission Noise
- Shift tower interchange
- Lsj and lnf differences
- Ecotec to 4t65e adapter
- A/C Compressor Clicking
- 4t65e standard output shaft vs. HD output shaft
- 2009 SS trans noise in 3rd and another question
- crankshaft pulley
- Question for those with KY on F23
- How to properly adjust shifter? (Ottp/TWM)
- 4t45e performance rebuild
- Help PLZ help transmission 2006 cobalt ss g85 opt mu3
- Dipstick pop out
- 2.2l heat sensor going in and out please help
- ZZP OEM Flywheel
- Shifting and linkage
- shifting issues either stuck between 2nd 3rd need help
- 07 SS ECM problems
- will a 2.4l gearbox fit on my lsj
- Master Cylinder?
- Abs and tc light on after hub replacement
- LNF transmission help please
- Cobalt Shift Linkage
- transmission problems
- Zzp short shift mod, bps cable clamp, solid shifter bushing
- trouble with NLS help
- Can i swap a clutch pipe from one trans to another?
- HAWK High Performance Street 5.0 Pads
- Ss/tc rear brakes?
- This is why no one should use GL-5 in our transmissions
- Trouble with the tob?
- Best quality axles?
- STS Cable Clamp
- gm upgraded clutch test
- First Time Buying Clutch
- F35 5th gear nut availability
- Intermediate shaft for SS/SC F35 trans
- ETS (traction control) problem
- Best short shifter for lnf?!??
- Popping out of 5th.... cannot get roll pins out
- Exedy clutch
- clutch and shifting
- About the engine noisy of 07 cobalt ss/sc
- Please, any advice appreciated.
- Slave cylinder advice?
- Redline Mt-90 or Redline Heavy Shockproof?
- 3rd gears grinding
- short trow install reverse lockout help
- Car stuck in 4th gear possibly bad Shift Linkage. Any part number or where to buy?
- need a new clutch, couple different questions
- b&m short throw shifter?
- F40 kit Discontinued?
- cv axles and air ride
- TWM solid shift bushing install
- Ever have shifting assembly issues?
- 2.4 Motor Mount
- need help please
- Flywheel Pricing - WTF
- axle seal install
- Will Cavalier hubs fit on my LSJ?
- axle bind question
- F35 MU3 parts
- traction control on non abs car
- Clutch slips
- Southbend slips
- Shifter comes out of cable
- short shifter install issue
- Shifter not going all the way into gear, feels weird
- Gearbox swap
- Axle Seal/ CV Axle Installation Problem
- Will my clutch hold?
- HELP PLEASE? Ticking from engine bay like a BAD gasket, gets LOUDER w/ BOOST PSI??
- Do I need to have the 4.45 ring and pinion cryo treated?
- TWM compared to BPS (noob version/pic)
- New clutch kit and transmission
- Powell Stage 2 Mounts
- Installed the Powell stage 1 trans mount kit
- LNF replacement axles
- Power steering
- ttr auto motor mount for ls
- Changing the fluid.
- finishing up my clutch swap,few questions!
- Just replaced my clutch and slave cylinder is defective?!
- clutch pipe fitting/clutch pipe leaking
- 06 SS transmission rattle
- Loud clunk (metal on metal) when giving very low throttle at low speeds and shifting
- clutch hydraulic fitting BAD!!!!!!
- 07 ls trans issue.
- redline clutch help WTF
- Am i screwed?
- LSJ vs LNF Tranny
- Steering wheel and breaks rattle
- 9-3 and cobalt ss trans interchangeable?
- No Clutch Pressure
- 09 LNF clutch options
- Dash panel reinforcement?
- Quick question for u 400+ whp lnf's
- Shifter Housing Bushings
- drivetrain upgrae
- Shifter linkage play, is it normal
- I need LSD
- No start: Clutch position sensor 09 TC
- motor mount problems?
- Advice
- Tranny hard to shift after WOT...
- BPS Short Throw Shifter Knob Question
- Lucas Stabilizer in Transmission
- Need Rotor Part Number
- New Brakes/Rotors
- LNF Stiff Shifter
- okay trans/clutch experts... whats wrong (TRANS IS OUT)
- F35 Upper Transmission Mount
- KY Stage 2 Clutch
- Bench bleeding the TOB
- No Gears Help
- new clutch
- F23 Clutch pipe number?
- Rotated Mount Spacers
- F23 Clutch kits opinions/reviews/options
- 08 LT TCU question...
- The Official KY Clutch Thread.
- Grinding in tranny.Anyone?
- please help, no gears!
- Mechanical or Electrical?
- 4th gear popping
- Clutch Job this weekend!
- Odd shifting issue.
- urgent help with mu3 transmission.
- Scary Special...
