View Full Version : Drivetrain
Pages :
4]
13
14
- 07 SS/SC axle shaft size
- Ralco cavy STS installed on F23
- 4.45 gears
- M86 vs MU3 cylinders?
- hard time getting the car into gear
- Clutchmasters twin disc clutch
- zzp f40 swapped cobalts!!!
- clicking sound
- TWM knob on Hurst shifter
- FX300 clutch grab adjustment needed?
- reducing torque steer
- Auto to Manual Swap!
- Vibration while accelerating at 45-55 mph
- Help! 2007 Chevy Cobalt LT 4door Sedan, 2.2 4cyl, Automatic
- transmission tune question
- ARP 209-2801 Flywheel Bolts?
- Help! Losing clutch pressure!
- Spec stage 2+ question
- Any decent fixes for the f35 roll pin?
- 2008 Saab F40 info
- F25 Saab transmission in Cobalt SS??
- 2nd Gear grinding
- Transmission Ringing Noise (While Driving)
- Im frikkin pissed! "New" Clutch slipping terribly!
- Strengthening the F23
- Transmission won't go into reverse--HELP
- 40% off on F40 Transmissions
- Arp flywheel bolts
- Short throw shifter question
- Clutches...
- **Interest Check!** Shift knob adapters for OEM SS Shifters
- Intercooler pump problems
- Picking Right Clutch
- Broken Cable Clamp
- 5th Gear Grind
- drive shaft question 2006 cobalt ss supercharged
- KY Cluth + Flywheel?
- Stiff shifting
- Shift linkage alignment?
- clutch slipping and lsd question
- Rear trains mount, is it shot?
- What did Powell send me? Front tranny mount.
- New clutch question
- Clutch Master Cylinder Size
- Lower F23 Trans mount
- Any 6 speed owners?
- Turbo 2.2 Next Upgrade?
- Possible to interchange front wheel hub with ABS on non ABS car?
- Clutch prob
- New Clutch time
- Warranty on CV joint boots. Help?
- will 2.2 4t45e directly fit and work with my 2.4 4t45e
- Replacing Clutch Switch
- Need advice please!
- Violent shaking on 1st gear
- LSJ ZZP Axle WAY too short??
- Shifter Wobble
- Rear Trans mount, Good or Bad?
- Input shaft, Clutch or TOB? opinions please
- Need help with clutch
- Cost to thread ss/na shifter
- Need advice on a new clutch
- best clutch for 05 SS/SC lsj
- goes into every gear but doesn't engage any gear
- 4T45E 2nd Gear gone
- B&M auto shifter?
- Being a pioneer again: info
- GMPP clutch
- need help with upgrading brakes
- pacesetter headers help
- ZZP 3 Chamber Cat Back
- Limp mode affects trans?
- A Closer Look at BPS Knobs!
- South bend clutches
- Engine support for transmission removal
- fluid question
- slipping clutch
- Installed lnf trans mount and shift cable bracket
- need help..tranny problems?
- GMPP Stage 2 clutch
- WNTED- Ued tranny to fit 2007 Cobalt SS/SC
- how to stop torque steer
- Replaced blown LNF clutch with GMPP clutch from CED
- Wheel Bearing Replacement
- LSD worth the upgrade?
- 2007 ss/sc 2nd gear shifts hard and grinds
- Losing pressure in clutch at WOT
- 160k miles.... Time for new clutch
- Cosmo Racing STS
- Loose shifter
- New Cable Clamps from Billet Pro Shop!
- Getting ready to do clutch install
- Big thanks to KY clutch and TTR!!!
- CV/axle shop brand removal info
- Scored an MR6
- Trans problems
- transmission leaking
- Changing the clutch on my 80K miles 2006 SS
- Introducing the Billet Pro Shop STS!
- Stage 2 Trans
- southbend clutch kits
- f35 and 4.45 questions...
- how to clean throttle body
- LSJ vs LNF axles
- 09lnf stock tranny max tq
- car won't go into gear
- why wont intermediate shaft come off?
- 06 SS SC Exhaust Parts
- Please help, right side popping!?
- Spec stage 3+ or ky stage 4
- Straight cut gears for f 35 cwp 4.45:1
- How replace & program body control module with used unit
- clutch
- HELP!!!!! with Clutch and Slave Cylinder issue...
- Clutch noise (vid)
- Flywheel
- driveshaft bearing
- problem maybe
- trans
- Need new Clutch!
- Weird reverse lockout issue?
- trans issues
- Auto trans rebuild
- Leaky Valve Cover gasket? Help please!
- Stall speed for ZZP TC
- Exhaust Adhesive??
- jerking??
- Terry11's 4t45/4t65 Auto Swap
- parts??
- 09 SS trans frozen on startup
- exedy stage 2 (3) puck clutch from thmotorsports review
- LNF - Extremely Notchy Shifting
- Exedy stage 2
- Anybody having any sales on clutches?
- need help on dot4 fluid choice?
- Clicking/chatter noise coming from from passenger side
- Removing shift cables from bracket on F35?
- Rattle/Chatter when new clutch is Disengaged
- What is this clutch part?
- Tranny and clutch tips
- got my trans fully built.....need input
- LNF Flywheel
- Zzp and Exedy clutch owners chime in!
- Damaged rotor
- Tranny swap
- Brake's squeek
- advance auto axles!! input
- :( balt problems
- DriveShaftShop Level 5 axles
- LSJ Shift Cable Bracket upgrade, did I get everything?
- Broken Axel or CV ?
- LNF clutch install CM1, throwout bearing blewout
- Exedy Racing clutch
- clutch or tranny issue?
- replacement clutch 2.2
- Add me to the list. 3rd gear dead
- syncro?
- what clutch?
- Don't move...
- Any F23 guys running an Excedy 3 Puck Stage 2 Clutch?
- another broken lnf tranny
- tranny breaking point
- Automatic drivetrain problem
- 07 lsd?
- ClutchMasters Stage 4
- 2 B light weight or not 2 B lightweight.
- Shift kit questions?
- Updated Rotated Mount Bushings
- No Lift Shift question
- 2008 Shift Linkage Broken
- ARP bolts for pressure plate?
- B&M shift plus
- Transmission Help!
- question : shift placement
- Axles
- Quick question. Clutch related...
- 07 ss with LSD
- Blown f35
- Happen to anyone else? Normal or something wrong?
- Symptoms for cracked flywheel?
- cams
- Is this a sign of my clutch going?
- Transmission problem!!
- Trans swap w/ goodies attached.
- Anally clutched! lol
- How big of a throttle body can i run on a stock lsj motor?
- reverse switch harness plug?
- zzp vs ottp stage 1 axles....
- Diff swap?
- interested in a tranny swap- I could use some experience
- National Oil Seal 3543
- Need help please, Axle seal part #
- removing axle seal question
- Upgrade to SS axles?
- Over heating at idle?
- Mobile 1 at Advanced Auto Parts
- Flywheel bolts question
- Comparison of these things! Need some opinions!
- Wanted stage clutch
- need help
- Drivers Side passenger side axle?
- Quick question!!
- hurst shifter thread?
- Clutch Options/ Opinion
- HELP!! Clutch Pushrod Install
- WANTED: Ingalls ETD ON 05 SS/SC
- Tranny Problems
- Clutch Woes. More Bleeding?
- Cluth making a grinding noise
- Trans fork help!
- shifter cable replacement
- Axle breaking?
- Shifter Linkage assembly bolts?
- Bwoody trans mount?
- install lsd in f35
- tranny or bearing?
- Trans help plz
- Light weight flywheel for street / occasional strip car good idea or bad idea?
- Will it fit?
- F35 experts come on in
- can't shift into 2nd...
- tranny locked; wont go into gears
- Ky stage 4 clutch review
- tranny bolt size/thread count
- Problem With My New Hurst STS
- trany problems
- BPS short shifter
- How to lsd swap?
- 09 SS hard shifting and reverse
- Why is my transmission taking a beating with 475+whp/tq??? How long till boom?
- 0TTP mount dies.
- Need clutch or trany already!?
- noob trans question
- 6 speed
- TWM Hard shifting
- Clutch problems ss/tc
- why you should only buy these from a certain vendor : small review
- soft, spongy clutch pedal
- Which Rotated Mount's To Buy?
- Barely any side to side . No 5th or reverse. New trans..
- Grinding Noise When I Let Off the Gas
- Someone help quick! What kind of trans fluid can I use for a 4.05 trans from zzp ?
- front trans mount bad is the rear bad too?
- Clutch Selection
- Exedy Hyper Single thoguhts...
- 20's Plus Hard 1-2 shift = Tranny Carnage
- zzp clutch/transmission
- Trans diagram?
- 02 sensor help
