PDA
View Full Version : Drivetrain
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17
  1. Broken shifter clip
  2. Hard acceleration= Zig-Zag
  3. OTTP stage 1 axle
  4. KY Stage 3 Max Torque?
  5. trans mounts
  6. crankshaft removal
  7. TWM Question
  8. NLS With Aftermarket Clutch?
  9. Shifter broken question
  10. Lsd
  11. Transmission Rattling
  12. HELP! Lost all gears & shifter will not move side to side
  13. Modding a STS
  14. GMPP clutch vs stock LNF clutch. What are the differences?
  15. Ordering powell racing rotated trans mount
  16. Slave cylinder and Throw out bearing
  17. 05-07 f35 tranny for sale w lsd
  18. will an LSJ flywheel fit an SS N/A?
  19. Found F35 problems..
  20. GMPP CLUTCH guys that are turbo swapped!
  21. Tranny mounts without engine mount?
  22. LNF Axles
  23. 2008 Cobalt Automatic Transmission Issue
  24. F23 Trans Removal
  25. New mounts
  26. stock clutch strength
  27. cable adjustment
  28. 5th gear help!
  29. LSJ and LNF clutches interchangable??
  30. KY Stage 3 Problem
  31. How easy is it to replace the shift cable for 2nd, 4th and reverse
  32. How easy is it to replace the shift cable for 2nd, 4th and reverse
  33. Spec Clutch Couldnt Handle the Power
  34. Need 2007 Cobalt Ss/Sc Shift cable p/n for 2nd, 4th, rvrse
  35. Squeaking and worn bearing sounds
  36. Is this synchro or linkage roll pin or other issues? Lost 2nd gear and 4th is sloppy
  37. I believe my car came with catless dp
  38. Built Tranny?
  39. To lift or not to lift?
  40. RWD manual trans for LSJ, what are the options - or are there any?
  41. Light weight flywheel
  42. anyone got a trans for sale
  43. auto conversion?
  44. ky stage 3 +1 slave bearing 0
  45. crossover cables
  46. tranny problems
  47. tips to make the stock clutch last longer?
  48. Tranny acting funny?
  49. Just found out I need a new transmission
  50. Ok so what happened here ?
  51. GMPP Clutch Bite Point Question
  52. Confirm Flywheel
  53. LNF Flywheel Vs LSJ Flywheel
  54. Are any of these good clutch kits?
  55. How similar is an Lef proceedure to this one?
  56. Cam Shaft
  57. Possible something loose in trans?
  58. Clutch Issue - Drops (No Resistance) & Cannot Shift - 06' SS/SC
  59. porshe 930 cv joints
  60. Car pulls hard under a load and has clunk in front end...
  61. clutch, slave, master cylinder, or shift cable?
  62. Trans End Case Leak?
  63. Firm Up Stock Shifter
  64. Emergency Cv Axle help!!!
  65. wtf
  66. Brake Fluid
  67. tranny problem.... help please
  68. Clutch Slipping or bad gears?
  69. It's Here!
  70. KY 6 Puck Clutch Owners + Squeak
  71. third gear broke again
  72. Axle question
  73. will 2.0 fit in a car with 2.2 trans?
  74. 5th gear w/reverse lockout???
  75. 1st, 3rd, 5th are fine: No 2nd, 4th, or Reverse?
  76. Engine making loud knocking noises on startup :(
  77. LNF's with KY stage 3
  78. New clutch?
  79. Throw out and clutch disc>?
  80. WTB LNF flywheel bolts.
  81. zzp Rotated mounts vs poly inserts
  82. Starting car problem
  83. Tranny Question
  84. Coil Pack
  85. Tranny Issue
  86. Please look.
  87. Tranny noises?
  88. MU3 help???
  89. Clutch Advice
  90. Transmission Problems Please Help Me
  91. 2.4 trans poly mounts - lsj trans mounts
  92. shifting probs
  93. Broken axle
  94. Looking for a good lsj lsd tranny
  95. Shifter cables...
  96. Genuine Saab Base Bushings
  97. question on rotated mounts
  98. LNF revised shifter bracket install question
  99. Who has a LNF running a LSJ trans?
  100. How to check if a TOB is good?
  101. will this fit ??
  102. f35 parts break down
  103. aftermarket shift knob fitment
  104. Auto trans pressure tables
  105. hubs or bad tires?
  106. Just replaced clutch, now gear rattle?
  107. LSJ TRANS w/ LNF LSD?
  108. New hubs?
  109. life throws curveballs....cracked my trans pan(i think)
  110. Axle Play 2006 Cobalt
  111. Issues with bleeding the slave/throw out bearing
  112. Lsd
  113. How do you know if your car has LSD
  114. Best Clutch
  115. KY clutch
  116. 07 SS/SC wheel hub torque specs
  117. LSJ Clutch DIY?
  118. help with finding tranny part.
  119. 2006 cobalt ss sc possible clutch diagnosis?
  120. a diff 5 lug swap
  121. LNF Clutch wtf?
  122. Left axle stuck (any ideas)
  123. Can you run Solid Engine mounts and rotated trans mount?
  124. straight forward question
  125. CED lsj upgraded clutch and experience
  126. CLUTCH Q's?? SWAP
  127. 0,01$ part fail
  128. clutch help ky stage 3
  129. Clutch Questions
  130. Clutch concerns
  131. Clutch opinion
  132. ZZP Stage 1 axles
  133. Help ASAP!!!
  134. Timken HA590088 Abs dosnt work
  135. ZZP stage 4 installed!
  136. Bad bearing in the tranny? HELP! :(
  137. have an ss/sc needing a new cluch
  138. weird clutch noise
  139. Q's about clutch change
  140. CED LSJ upgrade clutch kit
  141. HELP! Shifter Linkage Nightmare!
  142. Will this work?
  143. fly wheel
  144. Replacing clutch with transmission still in the car?
  145. Cobalt Ls transmission help
  146. Feeler - Might sell my spare G85 Trans
  147. Difficulty Shifting Into Fifth
  148. clutch noise.
  149. Final drive parts
  150. 5th gear
  151. Clutch rod
  152. how to make a seperate remote clutch reservoir?
  153. DOT legal radials on stock rims.
  154. How strong is stock 08+ manual transmission
  155. accidentally Clutchless shifted.. is it bad?
  156. where is it opinion
  157. new clutch
  158. Control Arm Bushings
  159. Transmission
  160. cant get axle off shaft
  161. Timken wheel bearings Made in China ???
  162. New Trans!
  163. SPEC Stage 3+ and Broken Trans, has anyone Had This Happen...
  164. Clutch install
  165. Axle Seal Write Up?
  166. How To Balance Shaft Delete
  167. Open and read update on gear oil!!!
  168. pop sound :(
  169. new clutch master?
  170. What is the G85?
  171. Pilot Bushing/ Bearing
  172. Where to buy new/used TC transmission
  173. Ok all you cobalt geniuses I need help! CLUTCH ISSUE?
  174. Ecotec valve spring install
  175. equal length on a 2.2
  176. Axle ratio
  177. Clutch Bleeder Valve "Clip"??
  178. Flush vs. Pan Drop
  179. 3 yr old clutch, sometimes slip..?
  180. Tranny scared the sh** out of me.
  181. 2007 cobalt ss clutch problems
  182. Making my own short shifter
  183. LSJ Clutch Question:
  184. Help!!
  185. TWM short shifter, cable clamp and bushing install questions
  186. clutch actuator pipe elbow
  187. Clutch Pipe?
  188. 06 SS auto to manual?
  189. Full face vs. 6 puck
  190. stock clutch question
  191. F35 Fifth gear removal in 15 minutes
  192. Any Way To Adjust F23 Clutch Engagement?
  193. Removing 5th gear
  194. Rwd
  195. Popping out of 5th gear
  196. Gearbox chatter - best fluid to quite it down?
  197. Help!!!!!
  198. Clutch Type LSDs
  199. Installed 6-puck KY Clutch. Questions!?
  200. KY Clutch - Official Release!
  201. So i started making a rwd cobalt
  202. Tranny Issues
  203. Best clutch?
  204. Auto Shift problems
  205. KY Clutch - Interest Thread
  206. Hurst STS issue
  207. Auto Leaking
  208. Dezod/TTR
  209. Difficult shifting when cold
  210. hurst sts problem?
  211. strange shake/vibration when pulling out
  212. just wondering...
  213. Weird Knocking Need Help PLEASE :(
  214. shift linkage
  215. no gears need help
  216. axle movement
  217. Transmission and clutch replacement on LNF! NEED HELP!!
  218. Getting the alignment and replacing the outer tie rods
  219. clutch? syncros? or both?
  220. f23?
  221. clutch and trans ???
  222. didnt know where to put this
  223. Installed clutch in Gdubs LNF
  224. Axles
  225. Quick clutch question
  226. What axles to buy?
  227. TVS with open diff?
  228. Trans seal leaking again.
  229. Clutch/Power-Steering problem
  230. Clutch noise driving on highway..
  231. Clutch slippage?
  232. Clutch problem?
  233. LNF Clutch Guys
  234. car problem :(
  235. Clutch chatter
  236. Suspension popping
  237. Play in axle? Output shaft?
  238. shifter??
  239. F23 Clicking Noise
  240. I think i have a problem?? HELP
  241. Shifter?
  242. Does shifting early damage the clutch?
  243. clutch bleeding issue.. Need help!!!
  244. Firm clutch pedal issue
  245. motor mount question
  246. Date code
  247. Torque Solution Motor Mounts
  248. Axles
  249. Recently Broke an Axle
  250. Thoughts on Vue transmission
