PDA
View Full Version : Drivetrain
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17
  1. F23 on to LSJ
  2. First-->Second Gear "Grey area"
  3. Auto trans fluid
  4. Spec 3+ Clutch and... what flywheel works best with it?
  5. This
  6. Swap F40 Gears in F35 trans
  7. Do i need a new flywheel if im getting a new clutch???
  8. Clutch "throw" feels long...
  9. Clutch Slipping BADDDDDDDD
  10. Whats wrong with my car?
  11. Throw-out bearing
  12. ottp stage 2 transmission mounts
  13. replacement clutch opinion
  14. 2010/23k miles/ 2.2 & drivetrain noise
  15. F23 Precision Machined Front Trans Mount
  16. Need help. clutch engaging very low.
  17. Transmission exchange
  18. fixed my shifter issue! (wasnt the roll pin)
  19. Do you need a pilot bearing?
  20. Gear whine going into 5th?
  21. KY Clutch Installed
  22. blown clutch
  23. we need a twin charged awd balt just to do it on um
  24. Will my SPEC stage 2+ clutch work on my new SS/TC
  25. Clutch bleed problem/maybe leak
  26. Act clutch kit??
  27. F23 Mounts
  28. Random, need 2 bolts on half-shaft bearing
  29. KY clutch 6 puck for sale
  30. shifter opinions?
  31. Clutch slave bleeder block question
  32. G85 trans
  33. CSS No SC 06 Cruise control problem???
  34. OBX Helical LSD
  35. 2nd and 3rd gear
  36. Centerforce Stage 2 Flywheel question..
  37. Regal GS 6spd swap into Cobalt?
  38. TTR Stop Mounts affect on Transmission Life
  39. strange shaking, need help.............
  40. In need of advice or help.
  41. Lost pressure in clutch peddle but still shifting smooth
  42. Changing Slave Cylinder
  43. bad news but good news
  44. axels / struts / shocks question
  45. ottp rotated mounts - still have wheel hop
  46. Shift issue
  47. clutch pedal queston??
  48. new slave cylinder problems
  49. 05 cobalt cv axle shaft how much to replace?
  50. ShiftPlus
  51. not a big car head......YET...need help
  52. car shifts hard at time then is smooth as butter.
  53. Auto conversion. Need help
  54. on throttle vibration, would like to find an answer
  55. another lsj axle post
  56. I need a clutch!!!
  57. Shifter starting to feel more notchy
  58. Just got KY Clutch
  59. noobie needs help
  60. motor mounts
  61. CBM Remote Oil Filter Adaptor
  62. Slave Cyl questions
  63. Clutch Slipping?
  64. Turbo Tech Racing Transmission Race Mounts
  65. Competition Clutch being developed for LNF/LSJ
  66. ARP fly wheel bolts and exedy hyper single?
  67. Mounts
  68. about to order a clutch. what all do i need?
  69. clutch fitment
  70. How to change tranny fluid in automatic
  71. Traction contol auto
  72. final drive
  73. F23 Transmission Shifting
  74. TWM Performance Cobalt Short Shifter Kit GROUP BUY! SAVE 15%!
  75. Finding Throwout/Clutch Release Bearing To Buy
  76. When WOT shifting 1st to 2nd, has trouble going in
  77. flywheel dowel pins
  78. Trans axle??
  79. Sloppy shifter....
  80. clutch starting to slip or wheel spin in 3rd?
  81. Clutch Master Cyl.
  82. Lowered, rotated mounts, rack spacers?
  83. Clutch Help on 06 SS/SC 2.0L
  84. 2.2 Aftermarket Axles
  85. Question On Clutch Kit
  86. Having A Hard Time Getting Into Reverse
  87. switching to rear wheel
  88. So, ARP studs out of stock? nope.
  89. Ottp stage 1 axles on sale!!
  90. Clutch goes soft after bleeding.
  91. Lnf tranny fluid
  92. Clutch replacement parts?
  93. short throw decision?
  94. Help me diagnose a grinding noise while braking
  95. Shift plus question
  96. Tranny/Engine mounts?
  97. What clutch/flywheel to choose?
  98. 2.0 flywheel question
  99. Blown Clutch Apparent, but more problems?
  100. Roll pin part number? And ARP bolts with GMPP?
  101. another tranny question
  102. help! quick connect for slave cylinder
  103. ZZP Trans Installed
  104. SC F35 guys look here!!!!
  105. Front Transmission mount tech spec question
  106. 2010 with bad axles?
  107. 3rd, 5th gear goes into neutral on deceleration..
  108. Aging auto trans
  109. Bad Slave Cylinder?
  110. LSD Input
  111. Simple transmission question
  112. zzp vs ottp mounts
  113. Broken clip under shifter.. what is this?
  114. gmpp clutch question
  115. Shifter keeps popping out of place?? help!
  116. I'll leave this here..
  117. power steering broke
  118. shift knob size?**free stuff**
  119. KY Clutch owners
  120. Help!!!
  121. zzp rotated trans mounts
  122. Need Input. Cars shifts like a old tractor.
  123. Flywheel questions LNF vs LSJ
  124. Clutch Problem
  125. Leaky Something...?
  126. knuckles
  127. Clutch pedal creaks????
  128. Is this sound normal?
  129. Sticking in gear.
  130. So rev matching a downshifting, good?
  131. problems with clutch
  132. Intermediate shaft bearing????
  133. quick question- TTR engine mount w/ ottp stage 2 trans
  134. new clutch?????
  135. axel lsj
  136. throw out bearing bolts?
  137. So need the advice
  138. clutch and flywheel.
  139. Broken Tranny or Something less Serious?
  140. axles
  141. Clutch for sale
  142. transmission
  143. Help with "Reduced Engine Power Message"
  144. need help with shift cable install
  145. Clutch Install Tips
  146. how to replace shift cable
  147. ACT Clutch
  148. Lightweight Flywheel?
  149. throw out bearing?
  150. replacing clutch ?'s
  151. ZZP LSD Tranny.
  152. f35 going into a 2.4
  153. 2.4 tranny upgrades?
  154. trans fluid
  155. clutch pedal feel?
  156. Rear Rotor Change Question
  157. Would this fit ?
  158. How much for left axle and right boot?
  159. at 30mph loud humm from front tires?
  160. zzp rear trans mount
  161. trans
  162. Rotated mount installation M35 LSJ/LNF
  163. can't get linkage off shifter bracket
  164. ZZP stage4 clutch review
  165. Trans Fluid for m86?
  166. trans?
  167. Will SS shifter bolt into my LS?
  168. Tranny worries...
  169. what beefer?
  170. Fidanza vs. stock flywheel
  171. help!!!!!
  172. Look at this blown lnf clutch
  173. AUTO Vibration
  174. ZZP rotated mounts?
  175. zzp 4+ vs. clutchmasters fx400 on a 2.2?
  176. Hurst STS Thread Pitch
  177. New Trans Mounts
  178. clutch / brake fluid resovior
  179. installing shifter..need help!
  180. Slave Cylinder Extention?
  181. clutch line?
  182. Help lol
  183. Shifting!!!!
  184. Low brake fluid
  185. still rough to get in gear after wot
  186. zzperformance cv joint?
  187. Trans Filler & Odd Vibration.
  188. Cobalt turbo clutch on SS/SC successful swap!
  189. Blew the tranny? no 2nd 4th reverse
  190. clutch install
  191. Clutch Rod Came Loose???
  192. Clutch Ideas
  193. Genuine Saab vs TWM shifter base bushings?
  194. Rear disc conversion
  195. new clutch
  196. Steering wheel/car shaking between 55-65
  197. clutch slip into second
  198. VIDEO: Trans sound, pretty odd.
  199. Wont go into gear after wot.
  200. TWM base bushings and cable clamp
  201. Love the new ottp stage 2 mounts
  202. All you clutchmaster guys out there..
  203. Axle stuck in trani !!!!!!!!
  204. transmission leak
  205. quick question for anyone with a TWM shifter
  206. GM Upgraded Clutch for LSJ
  207. can the lnf or lsj transmission interchange with the f23 ?
  208. trans rebuild
  209. LNF Tranny on LSJ?
  210. 5th gear
  211. Trans Service Mistake
  212. Hidden Hitch
  213. FINALLY an option for us f35 guys. READ!
  214. SMG Built Race Trans & 06' TCM don't mix
  215. clutch install on lnf
  216. Tranny ?
  217. TC axles
  218. Axle bind..?
  219. Shifter feels sloppy, roll pin or shifter?
  220. Clutch brands
  221. Aftermarket flywheel for GM LSJ upgraded clutch
  222. Slave Cyl. Leaking
  223. GM coolant supplement pellets
  224. I think my roll pin is on its way out the door finally.
  225. Changing the fluid.
  226. ACT Clutch
  227. TWM short shifter
  228. flywheel has a blue tint
  229. Transmission Died!!
  230. Slack in transmission
  231. BOV for my 09 SS?
  232. gm lsj upgraded clutch
  233. F35 Complete Parts List
  234. tranny question?
  235. ESC Problems
  236. Axle Seal Install?
  237. 06 cobalt, gear problems!
  238. Second opinion on possible deformed rotor?
  239. LNF or Turbo 2.4L
  240. Escapeing the "clutch"es of the evil
  241. strange auto tranny noise? help?
  242. hub assembly
  243. LNF Clutches, Holy Hell
  244. New Injectors?
  245. act clutch slipping after new install
  246. which clutch for stage 3?
  247. clutch bleeding HELP!!
  248. LNF Clutch Labor
  249. F35 Trans Assembly
  250. Which Clutch
