- help! shifter wont go in gear after clutch install
- my trans
- transmission differential
- tranny leak
- Quick Ingalls Torque Dampener Question
- Spec Clutch question
- Steering Problem and Squeaky Breaks?
- Where do I get parts for my F-35 transmission?
- Clutch not disengaging
- Just installed
- Wheel bearings Timken or Pricision
- anybody know the torque specs
- No Gears!!
- just got the car and already a problem
- Help with an auto to 5spd swap
- Clutch
- non lsd diff problems
- 2.2 auto tranny flush questions
- 07 lsj. lsd or not
- LNF spindle nut
- rough ride
- damn 2nd gear
- Hard shifting into gear
- Half shaft problem
- just ordered
- Will the dealer give me trouble? PIC
- how do i remove the PCM bracket
- LSD Help
- LSJ clutch in 2.4??
- tranny fluid
- how to chage linkage roll pin
- tranny help
- Does anyone know
- lnf slave = no boot?
- Will the 2007 limited slip tranny drop into a 2006?
- transmison out of whack!
- clutch problems
- Replacing Clutch
- how to tell if clutch is going out..
- Which Clutch
- How to change the shift cables?????
- 2.4L want to LSD
- help, 1st and 3rd gear jumping out of gear and grinding
- getting new clutch. flywheel ??
- clutch slipping
- TWM short throw shifter
- mabe a issue about my clutch
- Clutch question
- GM Part# for GMPP stg2 clutch?
- Automatic to Manual Tranny Swap
- Clutch issue. plz help!
- Auto swap into a SS/TC?
- trasmission fluid leaking from cv boot?
- Looking for a B&M Short Throw Shifter
- stock 2.2 axles?
- Bouncy Bouncy Bouncy
- Car wont move in any gear
- Heavy Traffic
- Getrag 5spd Syncro Issues
- why do i need a new slave cylinder?
- Outer tie-rod and control arm bushings bad??
- clutch help for a 2.2
- New clutch 101
- Small issue with steering....
- where to find clutch disc
- Power Steering
- Trans fluid, same used in RL and SS?
- Linkage problem?
- Clutchmasters Stage 4 Clutch
- Another Wheel hop thread
- ? for ppl w/ SPEC 2+ & 3+
- In need of a short block.
- Wheel Hop With Full Solid Mount Set Up???!?!
- clutch got put n lastnight but when i picked it up...
- i need new trans i have a few question
- Transmission Noise
- transmission
- bell housing
- Will SS drive axles
- Ottp mount question
- g85 trans finally got in yay
- What might be wrong?
- Clutch replacement
- aluminium flywheel
- is my clutch slipping???
- ACT Clutch
- clutch question
- gm upgraded clutch..... do i need to?
- clutch gone at 30k!
- Weird popping noise after clutch install
- help!
- Gm awd??
- hydraulic clutch fluid
- 2006 45k dead clutch
- read me and respond damn it! =D
- GMPP anti wheel hop/ SSTC front and rear trans mounts installed!!
- 2.4L F23 Trans Clutch
- F35 Tranny help
- lsj trans oil capacity and plug locations
- ok this is new for me. e-brake issues?
- Clutch HELP AsAP!
- passenger’s side intermediate driveshaft mount
- my clutch blew up lol
- Tranny Shifting Hard ?
- gmpp clutch
- Just Installed New clutch
- Wheel hop in rain
- Huge discounts on in-stock Magnaflow exhaust systems @ PFYC.com
- catastrophic failure: cv axles
- spec 3+ people...
- In NEEDS of a tranny
- help! drivetrain issue
- clutch decision......
- 07 ss cobalt need good clutch
- what clutch?
- 2.2/2.4 Flywheel comparisons?
- Flywheel with no dowels
- small question
- Need help with clutch issues
- Clutches and Pulleys
- super cheap act kit
- GM Clutch upgrade kit
- Power steering!!!!!!!
- weak clutch
- need trans help ASAP
- clutch issues
- 6-Speed on an LS
- Mounts
- funny noise when releasing clutch when downshifting...
- short shifter
- SS trans swap
- Those of you with aluminum base bushings, your opinions wanted
- B&M shift+ HELP!!
- Anyone runnin aftermarket lsd hellical or otherwise?
- Trans oil for 2008 2.2L
- Perfect Shifting from 1st to 2nd
- 2nd gear not going in
- Take off and stop click from front of car. key stuck in ignition!
- Thinking about it
- clutch not disengaging?
- centerforce clutch
- LNF-LSJ Axle compatibility
- Do Rotated Mounts Cause CP Fitment Issues?
- SS trans swap??
- clutch slave cylinder
- Eaton Prototype LSD
- OTTP or TTR Mounts for LNF?
- Auto trans help
- 2.2 clutch and axle question
- broken cv shaft.
- replacing clutch...........epic fail
- Engine Break In
- 13,900 miles and clutch is almost completely shot
- Ticking noise (NOT MY ENGINE)
- LSJ cluth install issue.
- how to install axle - video
- Broken axel Help please!!
- SS/TC short throw on an LT
- Hurst STS on T/C
- Tranny drain or fill hole???
- ss trans issues
- stiff clutch
- 710 Cap??? WTF
- Need some quick 09 SS/TC Clutch advide
- Backwards Shift Knob (Pic)
- broken passager side axle
- What did I break?
- CBSS T/C Owners with aftermarket clutches: Please read!!
- Stock Clutch Poll
- tranny ?'s
- Trans problems help!!!!!
- Automatic Drivers
- Chicagoland Trans/clutchwork
- HELP, I need F35 tranny diagram...
- F35 Transaxle Ratios/ Top Speed
- difference in 06 ss/na and ss/sc shifter
- Best short throw for 2.4 ss
- Iding a trans
- 2.4 head on a 2.2????
- passaxle issue
- clutchss
- Shifter Plate: Where to buy one?
- Transmition Info
- Does anyone elses car do this..?
- WTF!! 5th gear is hard to get into?!
- 09 SS/TC shifter cable problem
- SS/SC Axle seals
- Finally got my clutch problem fixed(pics)
- clutch/brake question
- Help with 96 Z24 cavy
- 2009 Cobalt SS broken
- shift problems, is it the clutch?
- Clutch troubles
- in need of an 09LS balt short throw
- Is there a vin digit that denominates LSD?
- downshifting bad and good???????
- GMPP clutch break in
- 09 TC trany clunk going into 2nd.
- Cross Drilled, Slotted, both or Smooth?
- Cryo?
- Problems with third and fifth gear popping out after transmission install..
- bleeder valve leak HELP
- What should I look for when buying a used transmission?
- cant press back the brake piston
- Transmission oil
- Trans different ?
- which one
- Suggested setting for Launch Control button
- SPEC SC073-3 08+ Cobalt SS/TC Stage 3 Clutch Kit
- Normal or potential clutch/trans problem
- Help!!
- Wheel bearing?
- Need a little help/info
- Clutch
- what all does the gm warranty cover?
- Kind of a weird question... Shifter stiffness
- trans swap?
- clutch install
- Flywheel good or bad
- Just bought a fidanza flywheel and clutchmasters stage 1 clutch
- Tranny and Engine Mounts
- Clutch's Experts pls hlp
- Do I need to replace my clutch?
- Sequential transmissions?
- Axle :(
- GM Automatic Transmission fluid in Saab F35?
- First Thoughts After Installing TTR Motor Mount
- 5spd Swap On An Auto 2.2L
- Hurst short Throw
- LSJ and LE5 trannys
- Problem with shifter??
- The Clutchmasters fail continues....
- Short shifter
- Ecotech Clutch upgrade...
- Which Clutch
- Question on GMPP trans mounts
- Manual vs. Automatic
- Need clutch help
- wont go into gear(buzzing sound)
- squealing from front left wheel
- caliper question
- Need new brakes and rotors ASAP!
- Chevy guys, I need help
- Best brakes??
- Need parts
- LNF's with aftermarket clutches
- motor & trans mounts??
- New '09 SS trouble powershifting
- Clutch Request
- Half-broken clutch
