PDA
View Full Version : Drivetrain
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
  1. Stupid loud front end clunk
  2. Cobalt SS Racecar - F23 Fluid Leak (Vent?)
  3. Ecotec Transmission Gear Ratios/Final Drives
  4. 5 speed compatibility sc and tc
  5. 06 lsj p0017
  6. Can I move side trans pan to change shift solenoids without removing the pan?
  7. car has p0700 and p0757 codes
  8. SP Performance Rotors & Pads
  9. F35 Rebuild labor time
  10. Lnf F35 Rebuild Cost?
  11. Is this a g85 LSD?
  12. Lnf Cobalt Trans Noise Help
  13. Automatic Trans Need a Picture of Science
  14. Still trouble shooting 4th Gear low RPM Loud Noise
  15. Diver side axle seal leaks!
  16. Shifter won't move side to side in nuetral
  17. LNF Trans help
  18. Clutch Engagement Issue
  19. 2007 LSJ 1st gear clicking noise
  20. New clutch master cylinder, blows clutch line off when trying to bleed?
  21. Before my car pops out another axle
  22. Roaring noise when accelerating after coasting.
  23. CV Axel going?
  24. Transmission Identification Question
  25. Failing CV shaft? Fun with cobalt suspension/ drive train
  26. No Response from Crate engine depot
  27. Reverse Gear
  28. Rebuild 4.05 or no?
  29. Lnf F35 stuck in 3rd (maybe) but shifter feels like nothing.
  30. LSD vs FZ Transmission, Speed Sensor Bung is Different. Any Options?
  31. F40 guys, did your fuel economy change?
  32. Zzp stage 1 axles, normal?
  33. cobalt ss lnf clutch
  34. Changing SS/SC F35 fluid
  35. Need 07 cobalt tranny. Please help.
  36. Is a lsd transmission a direct bolt on for a lnf
  37. Rear Axle Replacement - need some assistance
  38. Are all pre-08 5-lug axle splines the same?
  39. LNF Gearbox lost 5th gear, need scheme, part list
  40. 05 SS right side axle came out, pics
  41. Aftermarket clutch interchangeability??
  42. f40 flywheel install
  43. Rough running 2.4 under load at low rpm
  44. 05 SS hard to get into gear
  45. Will Not Shift Into Reverse
  46. AC Delco Manual Transmission Fluid Color
  47. TC light + trans hard shifting
  48. Lsj won’t go into gear
  49. Welding Vibrant Stainless Mid-Length Header to Its Downpipe?
  50. trans help! anyone put a ss/sc trans on a ss/tc motor
  51. KEY Stuck...NOT SHIFTER
  52. LNF trans help
  53. Excessive transmission noise?
  54. Luk lsj clutch kit???
  55. Help car wont move!!!
  56. 2010 SSTC f35 mainshaft nut backed off
  57. Any guesses what this noise is (08 SS)
  58. New GMPP clutch installed
  59. F35
  60. What Trans fit an 08 SS LNF?
  61. Another will the GMPP clutch hold my SS/TC thread....
  62. F35 tranny noise never answered...
  63. Lsj keeps popping the crank shaft position sensor relay after removing motor
  64. F35 to f23 swap on lsj, almost there! Couple questions.
  65. OBX diff into F23
  66. F35 transmission rebuild or replace?
  67. Gmpp clutch kit
  68. Cobalt SS 2.0 turbo something broke? Trans? Help?!
  69. 9-3 aero 2.0t saab tranny in cobalt ss 2.0t????
  70. p0700 code and shift problems
  71. Clutch acting up
  72. Opening in bell housing???
  73. F23 Quaife LSD install
  74. Steel light weight flywheels
  75. Proper clutch bleed question
  76. Tob
  77. Trans problem....any help is appreciated
  78. Tob or light flywheel common issue?
  79. left/right CV axle inner stub difference?
  80. clutch won't engage after driver side CV axle replaced
  81. Sout Bend clutch, require or recommend spacer?
  82. Stock flywheel with aftermarket clutch?
  83. F35 trans info
  84. slave cylinder leak after clutch install - need advice
  85. LSJ 5 speed
  86. Plugging f35 axle holes for cleaning
  87. Clutch not disengaging
  88. Drivetrain combination
  89. Clutch Replacement
  90. Tcm
  91. Few STS questions...
  92. Manual transmission
  93. older versions of Trifecta EZFlash?
  94. Af40
  95. Loosing pressure on and off
  96. Transmission swap?
  97. Clutch pedal pressure!!
  98. Cannot shift into first or second... need help!
  99. LSJ with F23. Modified T-stat housing?
  100. Transmission question
  101. Differences between Cavalier F23 and Cobalt F23
  102. Installing F40
  103. auto trans cooler fitting? hard to find.
  104. Pscm chatter
  105. L61 clutch questions
  106. Transmission suddenly lost all gears. Looking for advice
  107. What am I?
  108. Clutch went soft wont go into gear
  109. Which Trans Mounts?
  110. A/C Delete Pulley - A/C Bypass 2006 SS SC
  111. KY 4+ Clutch
  112. Car stopped torque steering
  113. Sticky shifter??
  114. Clutch slip?
  115. short shifter kit??
  116. 05 2.2 manual transmission mount bushing
  117. I need Recommendations for a new clutch
  118. tranny failure with 500+hp big turbo cobalt..what can we do?
  119. Aging of the Cobalt and Trans Parts
  120. Need Info
  121. New here, in desperate need of info
  122. New here, in desperate need of info
  123. Does 4t45e hold up with boost
  124. Clutch stuck in first.
  125. Need some input guys
  126. short shifter
  127. Wheel bearing
  128. ZZP - 2.2/2.5 9.5" Clutch Kit
  129. Car won't move after axle replacement!!
  130. New clutch making horrid noise
  131. adapter plate
  132. part number 25827450 cant find! help!
  133. Wheel bearing issue
  134. Pulley kit?
  135. Hub Spacer
  136. Exhaust?
  137. Axle problem
  138. Cv shafts question
  139. Clutch or bearing? (Video)
  140. F40 help
  141. Front end Clunking
  142. F23 trans differences
  143. Please help!!!
  144. Lnf bellhousing dust cover
  145. 1st through 4th gears won't engage.
  146. What is this? Pic included
  147. F40 6 speed install
  148. Clutch help
  149. Fidanza flywheel anygood
  150. 05 cobalt ss/tc
  151. Clutch Prep
  152. Need clutch kit input...Clutch masters or Centerforce?
  153. Pedal Losing pressure
  154. Holiday Deals: Reasons to Buy ZZP Trans Mounts?
  155. KY Performance F35 Twin Disc Released!
  156. LuK Flywheel Updates
  157. 35/35 sprocket drive chain set in high revving 4T45-E build?
  158. F35 transmission repair
  159. flywheel bolt specs
  160. Exedy OE Clutch Rating
  161. Clutch Master Cylinder Replacement
  162. Clutch Pedal Play
  163. Flywheel Bolts
  164. F35 Clutch alignment tool 3d file
  165. LSJ clutch on L61/LE5 flywheel
  166. Stuck in gear after clutch install
  167. Humming....bearing or cv joint
  168. Weird noise coming from axle
  169. Clutch won't hold pressure long after bleeding
  170. F35 tranny question
  171. Cobalt SS/SC head and cams
  172. Clutch bleeding problems
  173. Blown Transmission
  174. Auto Trans Issues Cobalt LT
  175. Blue Shifter Piece under Shifter spring that "locks" out reverse
  176. Ottp STS
  177. ZZP TOB Spacer
  178. Engine support when removing engine cradle
  179. Clunking noise when shifting up.
  180. Stock shifter adjustment? New shifter?
  181. Looking for clutch LNF 315 whl tq
  182. 05 Cobalt SS transmission swap
  183. 2nd Gear Grind
  184. Transmission to Axle Part
  185. KY stage 2 clutch kit for F23
  186. Axle shaking engine
  187. Cv axle help
  188. grinding reverse
  189. cv axle thump
  190. No 4th after 3rd gear pull?
  191. Zzp Throw out bearing spacer
  192. Tranny help!
  193. Clunking coming from inside transmission
  194. Roll pin problem need help
  195. Performance Autowerks vs ZZP built transmission
  196. Popping/clunking noise
  197. LNF sometimes grinding 2nd and 4th
  198. LNF - Third Gear High RPM
  199. cv joint boot for GM upraded wheel hop axle
  200. Helpppppp!!!!!!!!
  201. Oil and clutch questions
  202. Weird shifting/clutch
  203. F35 MU3 shift lever differences
  204. KY Stage 3 PLUS anyone?
  205. Info for taking apart an F35 trans
  206. Moving clutch and fw to new motor
  207. GmPp clutch still available for lnf Balts?
  208. Clutch over extension?
  209. Drivetran clunking noise..
  210. So i feel like i got swindled out of an extra 100$ From the Dealer.
  211. Performance AutoWerks Bleedable LNF clutch slave cylinder
  212. Got to change the axles..
  213. Transmission rebuild parts needed?
  214. Lsj replacement flywheel
  215. Clutch wont bleed? maybe?? or somethings wrong...
  216. Ottp STS help
  217. Shifter Cables
  218. Watch me break my clutch in this sweet video
  219. Axle or wheel bearing? Or something else
  220. LSJ rear axle beam in LNF??
  221. 3rd Slave cylinder in 1 year!
  222. 2009 cobalt ss 78k Miles rear tires worn from inside
  223. F35 Transmission Fluid Never Needs Changed Per GM!?
  224. Short Throw Shifter - which is best?
  225. Clutch Question/Problems
  226. Modified Gear Box / Shift Pattern
  227. Drivetrain slop in sstc
  228. Clutch question
  229. Hard Shifting
  230. Clutch issues!!!
  231. ky stg 3 clutch issue
  232. T/c and abs warning lights
  233. Transmission Mount Bolts
  234. Part number request. Clutch safety switch.
  235. Any how to for replacing shift cables.
  236. doing small build need input
  237. ottp stg1 rotated mounts? what are the benefits?
  238. What is this spacer for?
  239. ZZP is selling F40 kit again.
  240. Time for new shift cables?
  241. What is this...?
  242. reverse lights not being activated
  243. 2009 won't shift to reverse or 5th when cold engine not running
  244. Clutch questions 09 SS/TC
  245. HELP PLEASE!! need a gear for MU3
  246. Clutch is really high
  247. Automatic transmission difference
  248. Stick won't move out of reverse!
  249. SS/TC Front Pads & Rotors
  250. Abs module
