All Cars Café The landing pad for automotive discussions, news, articles, and opinions. A place for the community to kick back and chat about all cars.
Car won't crank please help
Old Jun 22, 2022 | 06:12 PM
Ryangaulton's Avatar
Hi I have 2008 pontiac g5 with a 2.2 manual and it won't crank it started off with no engine when key on and my scanner wouldn't connect so I replaced the pcm got the light and I was able to read the codes( 1 code crank position sensor p0315) and after talking to my dad he pointed out the security light and said that it may be why so I got rid of that Still nothing. The guy I got it off of tried to do a cluch bypass on it and the car only has one sensor on the clutch so want I asking if what could cause the no crank I can only think of two things the clutch sensor or crank position sensor
Old Jun 22, 2022 | 07:31 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
If the PCM was not reprogrammed so that the VIN code matches the BCM, then the immobilizer will prevent the car from running.
Old Jun 22, 2022 | 07:33 PM
will it stop it from cranking over or just running
Old Jun 22, 2022 | 08:09 PM
Iirc it will not allow the engine to crank.
Old Jun 22, 2022 | 08:23 PM
Ok ill get it programed but with the crank senors effect the car in any way ether not starting or cranking just wanna make sure I'm not gonna be chasing anything eles
Old Jun 22, 2022 | 08:44 PM
A bad crank sensor will still allow the car to crank, just never fire/start.
A bad clutch sensor will not allow anything to happen. Starter won't even activate.
Old Jun 22, 2022 | 08:55 PM
on my clutch sensor isn't bad just unplug I hope
Old Jun 23, 2022 | 02:16 PM
If the clutch sensor is unplugged, then that's definitely a problem.
Old Jun 23, 2022 | 06:11 PM
About my computer issues I'm assuming I need to go my local gm dealer to get the pcm reset, so now I'm wandering if they need the whole car or can I bring then the pcm
Old Jun 24, 2022 | 10:25 AM
A dealership will need the whole car. Way too many different PCM connectors out there for them to be able to bench tune a PCM.
There are alternatives though. I reprogrammed my own using HPTuners software. Most people that can do that will also need the whole car.
Ryangaulton
Jun 21, 2022 05:18 PM
paintballerr78
Apr 6, 2014 11:02 AM
LE5_AJ
Jun 6, 2010 11:30 AM
SloBaltS/C
Apr 29, 2010 04:44 PM
