RIP TVS Cobalt
Old Oct 19, 2008 | 01:57 PM
sehoublackss's Avatar
RIP TVS Cobalt
Motor blew last night...
...looking at beater cars now.
options
1. sell as is IF possible
2. replace all the stock parts including stage 2 tune, tow it to dealer
3. rebuild with better internals
I need shop recommendations, Houston area
Old Oct 19, 2008 | 01:58 PM
LScoupeTUNER's Avatar
damn dude.
sorry about that.
Old Oct 19, 2008 | 01:59 PM
Texas SS's Avatar
Damn man that sucks
and FWD Performance? haha
Old Oct 19, 2008 | 02:00 PM
boostedss26's Avatar
that blows sorry to hear. Rebuild it bigger and better
EXsoccer1921's Avatar
how much would you sell for? and what all have you done to the car?
Old Oct 19, 2008 | 02:27 PM
olivecj's Avatar
options
I'd definetly keep it man and build it with stronger internals. also if you sold as is you'll never get back what you paid for it so you might as well keep it and make it even better than before.
Old Oct 19, 2008 | 02:31 PM
RoelSS's Avatar
How did it blow? How miles on the odometer? what mods?
Old Oct 19, 2008 | 02:35 PM
rguti153's Avatar
damn you better had won....... so what are you planning to do with the parts
Old Oct 19, 2008 | 02:38 PM
R&C_rallySS's Avatar
Yes, would be very helpful information. Did a piston go? If I were you, depending on the damage I would rebuild it and forge everything. Once its fresh again with forged internals you will be ready to go and with a good tune this won't happen again.
Old Oct 19, 2008 | 04:07 PM
54k on the odo
I'm guessing a piston, there was a huge plume of white smoke and it sounded like a wrx.
It blew when i was playing with this other black cobalt I let him gun it in 3rd like 4 lengths ahead, just see if how much of a reel in Id do. In 4th the RPMs wouldnt climb when it started to get around 5k, then started to fall, then there was a blinking cel...
272 whp @ 6100, 254 wtq, psycotuned, Harrop 1320 80mm pulley, 60 lbs injectors, G85 w/ sunroof & xm, injen intake, gmpp cat, gmpp header, dual pass end plate, cx racing h/e, exedy stage 3 clutch/flywheel, ttr motor mount, ttr trans mount, drilled slotted rotors front and back
how much you think thats worth with and without the blown motor
Old Oct 19, 2008 | 04:09 PM
WhiteSSBalt's Avatar
Not a Sebring
how'd it go boom?
Old Oct 19, 2008 | 04:28 PM
how is the question... I spent time to make sure this is safe as can be.
Old Oct 19, 2008 | 04:44 PM
WSFrazier's Avatar
Seeing how stock motors are seeing 320-400whp, I will venture to say the tune. 3.15" pulley isn't moving that much air...
Old Oct 19, 2008 | 04:46 PM
pm'd. btw i'm just up in NE oklahoma
Old Oct 19, 2008 | 04:47 PM
slowswap's Avatar
Sounds like to much timing...or a bad patch of gas?
AjSS's Avatar
You could sell me the TVS... I wont tell anyone...
Old Oct 19, 2008 | 04:55 PM
idunn's Avatar
rebuild + cams, tune, 100shot. youll be close if not over 400whp on that blower. dooo itttt.
Old Oct 19, 2008 | 05:35 PM
roderick's Avatar
i will give you 1800 for the tvs if you want to sell it i got the money handy.
Old Oct 19, 2008 | 05:36 PM
Ok, I think I'm gonna get the forge internals and build it. I'll start a build thread.
heres my shopping list... Im assuming based on other builds
1. beater car/or motorcycle
2. http://www.turbotechracing.com/produ...idproduct=5094
I know compression is 9.5:1
I'm guessing yes to ring set
bore and coating no clue yet
3. probably need this http://www.turbotechracing.com/produ...idproduct=4991
4. arp head studs
hopefully no valves...
Old Oct 19, 2008 | 05:45 PM
06black's Avatar
the tune was your issue, hands down, no questions about it.
stock motors (mine included) have survived far harsher environments, and power levels.
you were on a fairly large pulley as well.
none the less, i'd forge her. Its easy to do and leads to plenty of fun once your done.
dual coated diamonds, new rings, fresh hone, head studs, and head work/cams if you have the cash.
get her re-tuned ASAP once shes back together.
good luck!
Old Oct 19, 2008 | 06:16 PM
idunn's Avatar
100 shot
Old Oct 19, 2008 | 06:22 PM
Axle Man's Avatar
send me them drilled slotte drotors i has $$$
/thread jack
Old Oct 19, 2008 | 06:25 PM
an0malous's Avatar
sounds like it detonated.
sorry to hear man.
Old Oct 19, 2008 | 06:28 PM
BoostedYards86's Avatar
wow def tune or gas related...
Old Oct 19, 2008 | 07:18 PM
supermantxz24's Avatar
what does him having a large pully have to do with him not blowing his engine? it has to do with how much boost and how much air he is forcing in his motor which was 20psi and not pully size. and thats alot of boost on a stock headgasket. sure their are people that do it but its not safe and sure it could have other things that have caused his engine to go but i think his headgasket blew and caused other damage. that sucks you just fixed your tranny and now this.
