South Pacific CA, NV, and HI
Las Vegas! Need help with LNF powered Exocar...
Old Jul 10, 2012 | 02:06 PM
StruttinSoul's Avatar
Exclamation
Originally Posted by ViperJustin
I really don't know how much this car has been tuned, or if it's been done at all. The LNF is new to me. Im used to Jeep 4.0 I6s and LSx engines. Those are super easy to diagnose and work on. This LNF is like rocket science to me. The cel will tel me I have a map issue, so I change it out, and it's still there. WTF???
I've heard about the airboat with the LNF engine, and I hope I can find someone in town that has that level of knowledge to help out.
Again, thanks for the compliments and for contacts for help. I really appreciate it!!!
Do you have bosch MAP sensors? Or are they the factory ones?
It could be a boost leak or a wiring issue, or O-Rings.
Old Jul 10, 2012 | 04:01 PM
Cobalt_Daddy's Avatar
you will be glad you stuck with the LNF over the SRT4/4G setup. it's a great little motor with alot of torque and decent on gas
Old Jul 10, 2012 | 04:16 PM
turbosmart4's Avatar
I love that intercoolr location idk if this will help much but I know a guy that swapped an lnf into a o7 cobalt . he is also a tuner(hp)... His name is tyler. 713 560 3889
Old Jul 12, 2013 | 04:01 PM
MADDOGCORPSMAN's Avatar
Originally Posted by RyRidesMotox
The HPtuners is a good bet. You can do just about anything with them...
OP- make sure the wiring to the MAP sensors is ok. There are 2 of them, one should be in the cold side charge piping and one should be in the manifold. Check to see which ones they are as well, if they are blue they are 3 bar MAPs and they need a special tune file. If they are grey they are stock ones. There is a known problem with the 3 bar MAPs concerning the wiring of the harness, if a dealer installed them in the car it was pulled out of they may ahve only used crimp style wiring connectors instead of soldering them together. I am pretty sure Terminator2 can tune that thing with or without the BCM connected to the car. The VATS system just needs to be calibrated I believe. If you want an HP tuner in the Vegas area hit up Joe or Chris Warner. They are both on here. Chris' S/N in Warner and Joe's is 07SSYellow. They have a HPTuner computer and should be able to get that thing going. PM Terminator2 on here as well just to see what might be needed as far as tuning without the BCM. HPtuners will be able to tell you more about what is wrong with the tuning anyways, because you can see what the computer is seeing.
Good luck, and if you have any questions let me know I'll try to help as best as I can, as long as I can get a ride in that mother effer later hehe.
I too need some help with mt 09 Cobalt tune. Any updates on the Warners?
Old Jul 12, 2013 | 04:03 PM
Sox-Fan's Avatar
Got Brakes?
Neither of them still own a Cobalt, and I own the HPTuners set they used to have.
Old Jul 12, 2013 | 04:16 PM
SalvageBaltSS's Avatar
this is a sweet car. Did OP ever getting it running right?
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
patooyee
Oct 1, 2015 01:07 PM
