South Pacific CA, NV, and HI
Need help!
Old Dec 14, 2013 | 03:14 AM
06black$$'s Avatar
Unhappy Need help!
can anybody help me i NEED my car to get SMOGGED asap and i have a P0171 & P0171 Pd code popping up on my car do i need to get a tune for my zzp 3" intake? Or can i just erase the engine code and go try and get smogged. I don't feel any performance loss from my car at all but i do hear a faint airy type of sound coming from the middle of the car when im light on the throttle inside the car. If anybody has experienced this problem or has any knowledge on this please chime in. I've been driving my car for like 6 months without tags lol and im done being bitched at by the cops. Or if there is any lick it and stick it places for smog that'd be even better. I'm in vallejo so if anybody out here or anywhere closer can help it'd be nice. Thank you in advance.
Old Dec 14, 2013 | 03:51 AM
jp1600's Avatar
I could tune you and get rid of the code, but either vac leak or intake code. From what I've seen without a leak with the zzp intake your trims will be off about 9% on the stock tune. Soooooo I would check for a leak
Old Dec 14, 2013 | 04:29 AM
06black$$'s Avatar
are there any common places that these cars leak from by any chance so i have a starting point on where to look at? i do have a couple cracked hoses on the boost solenoid but i ordered the hoses from gm and im going to replace them when they come in. Also would i be able to pass smog by just clearing the code for now and going to a test only?
Old Dec 14, 2013 | 04:31 AM
jp1600's Avatar
Check for a leak around the map as well
Old Dec 14, 2013 | 05:23 AM
Ontario's Avatar
Question newbie needs trunk help for 06 SS
Hi
I'm new to this forum and having trouble posting to all members to get a solution to my problem. Maybe you can help me a) post or b) solve my problem.
I've got a 2006 Cobalt SS that I took the battery out of and closed the trunk. Later I realised that the key won't go all the way into the tumbler of the trunk lock. I tried graphite and WD40 but the key still won't go in all the way. Next I tried to get the back seats apart far enough to put my hand in and spring the latch to lower the back seats. Can't get my hand in far enough.
Any solution to get into the trunk??
Sorry to bother you 07MetallicSC but I need a solution. Thaks for any help you can give!
subscribe78@gmail.com aka as Ontario on this forum
Old Dec 14, 2013 | 05:51 AM
06black$$'s Avatar
also can the timing chain tensioner cause the car to throw a p0171 code?
Old Dec 14, 2013 | 03:34 PM
jp1600's Avatar
No it cannot
Old Dec 15, 2013 | 06:38 PM
06black$$'s Avatar
just replaced my bank 1 o2 sensor hopefully that'll fix the stupid p0171 code.
Old Dec 16, 2013 | 05:07 PM
Tjolley's Avatar
i bet ur zzp intake has a hole in it
most ppl dont take the time to properly mount it.
check the area were the tube goes into the fender.
Old Dec 16, 2013 | 05:22 PM
Its a tough intake to fit.in there! Wish it came with some rubber padding to help it keep from rubbing
Old Dec 16, 2013 | 06:07 PM
jp1600's Avatar
i still think its the maf not seating
Old Dec 17, 2013 | 09:30 AM
Tjolley's Avatar
never seen a maf have a sealing issue unless the person didnt use a gasket.
Old Dec 18, 2013 | 11:21 AM
06black$$'s Avatar
i mounted it perfectly fine with no holes just some scratches because of how awkward it was to put it in. it scraped off a little bit of the black finish was all. i think i just need to get tuned for it because the o2 sensor was not the problem. either that or ill have to throw on the stock intake again.
Old Dec 18, 2013 | 11:23 AM
06black$$'s Avatar
Also my car passed everything on the smog check the only thing it didn't pass was the obd part where the code popped up. so I'm more than sure its that damn intake if anybody could tune me for it id be more than grateful for it
Old Dec 18, 2013 | 04:08 PM
06black$$'s Avatar
I threw on the stock intake so hopefully no code will pop up & i can pass smog already
