'06 Lt sedan clunking over bumps
Old 03-13-2019, 01:51 AM
Bdawg977's Avatar
Hey guys, my cobalt has had a clunk in the front for a while now but it's starting to get rather noisy and i'm not sure if it's links or strut tops, and i really don't want to just throw money at it so i was curious is there is an easy way to test either of the two culprits to see if they're bad. The clunk happens mostly over bumps but does happen when backing up on a tight angle
Old 03-13-2019, 07:37 AM
jdbaugh1's Avatar
You should be able to tell if it's your strut tops by opening the hood and observing the middle of the top hat as you push to bounce that corner of the car up and down. You should be able to see it move around excessively I'd think. To test if it is your sway bar end link just jack up the car securely, remove the tire and inspect the link. You should be able to tell if it has excessive play just by trying to move each end around by hand. Also potential causes of noise could be bad sway bar bushings or trailing control arm bushings.
Bdawg977 (03-13-2019)
Old 03-20-2019, 04:48 PM
Bdawg977's Avatar
Just to update what was found, my steering rack has internal damage so it's getting replaced
Jesse1991
05-14-2015 11:39 AM
buildmeanempire
10-08-2012 12:15 PM
Michael Kenter
09-10-2012 01:49 AM
hoop
09-21-2011 07:41 AM
KyFritz06SS
03-30-2009 09:30 PM
Quick Reply: '06 Lt sedan clunking over bumps
