2009 SS strut replacement and now car sits higher in front.
Old Nov 29, 2019 | 10:30 AM
Jeremy Lunn's Avatar
Hello, new to the forum. Hoping you guys can help. Recently bought my son a 2009 Cobalt ss. It needed the struts replaced. Went to Rockauto and bought Monroe 172179 quick struts. After replacing them I noticed the frontend is visibly higher than the rear. The rear shocks were replaced at the same time. I guess I just assumed that since I was searching under an 09 SS that I would be looking at the Fe3 or Fe5 struts. Can someone tell me if I screwed up and put Fe1 struts on? I also replaced the sway bar links with the 9 inch Moogs. Any info is appreciated.
Old Nov 29, 2019 | 10:51 AM
You put FE1 struts on. There are no FE5 quick struts, rockauto shows them as an option because they fit.
Old Nov 29, 2019 | 10:56 AM
Damn, I should have done my research. Too many cars and not enough time. I have a 2015 Challenger with BC coilovers and Eilbach pro's and it handles great.
Can you give me some ideas on a replacement set up? I have been searching the threads and people are all over the place with their set ups. Looking to get back to the original set up or better without spending a grand. Again, all info is appreciated.
Old Nov 29, 2019 | 04:01 PM
T-Man's Avatar
You can easily pick up an OEM FE5 setup for much less than $1K. Only thing I'd recommend is some KYB strut mounts over OEM.
Old Nov 29, 2019 | 05:51 PM
okay, thank you. Any recommendations on strut/spring brand?
Old Nov 30, 2019 | 06:56 AM
63 Nova SS's Avatar
Check out crate engine depot. They have factory fe5 shocks and struts. The also sell a complete plug and play kit with Powell yyz springs which make the car handle extremely well while also lowering it like 3/4". They are progressive handling springs that are worth the money. I had the same setup then down the road I upgraded the shocks/struts to koni but you don't want to spend that much.
Old Dec 1, 2019 | 08:02 AM
zeeky420's Avatar
Ottperformance has the bilstein set up for front and rear
VapeWI
Mar 13, 2015 07:18 AM
06Pursuit
Jun 13, 2012 12:57 AM
tonio5555
Nov 13, 2010 10:51 AM
Out1aw
Apr 30, 2008 10:23 AM
