Big Brake Kit?
your best bet is doing some research, iknow you can get cadillac CTS V Brembo calipers off ebay for like 300 bucks, or 160 new from gm parts direct, and your probably better off building ur own. i've been looking at the ctsv/brembo setup for both my camaro and cobalt. theres a guy on ls1 forums nearly done with the cts v setup. using the brembo calipers and corvette Z51 rotors since their thicker and fit the calipers.
^^ really i have heard some bad reviews on the SSBC set up....
i am looking for the whole kit, if TTR gets the brake package then i wont worry about it. but rotors, lines, pads, calipers.
IMO e brake is the last thing, the stopping power is what I look for
yeah you could leave it in gear. but i would like to keep the e-brake
Aaron so you know about how long the install time is for the SSBC kit front and rear? also whatever happened to that BBK you guys where custom making?
If you do a search on here for "ssbc" I have 2 threads on here with pictures of the kits. One from when they were black calipers and one from when I had the custom engraved "cobalt" calipers. Install is very straight forward. Unbolt old stuff, and the new stuff goes on. I'd say like an hour a corner if you do it by yourself. Working there has it's advantages
Cobalt has a kit for the zo6 setup... you need 18's and not the stock ss/sc ones as it sounds like there are some issues with clearing the caliper... link:
http://cobalt-addiction.com/handling.htm
it is under brake kits... sounds like all of the adapters are included
[QUOTE=Dunkinuts;2361807]yeah good to know, are you 18'' or 17''? i am still thinking on if i should go BBK or change out everything stock size
I had the 18's on my car. Should clear the ss/na 17's as well.
how do you post pics to your messages? If I knew I could send you an interesting brake set up for Cobalt/Ion with Performance friction rotors and CTSV rear brembos. ..but as I worked on this I concluded that for dollars expended, the stock caliper will work almost as well...just not look as good....
