build your own traction bars.
Old Nov 13, 2009 | 10:26 AM
phatnackySS's Avatar
Originally Posted by boltedbalt
would doing this on a 2.2 be drilling the same spot and would the lenghts be the same?
I'm not sure , but i think the 2.2 use different stamped steel LCAs
Old Nov 13, 2009 | 07:42 PM
Cobaltsky05's Avatar
awesome thread! I hated mine I got from a supporting vendor... I will build a set though just to have for the track. But with suspension travel and what not I do not recomend daily driving on these cause you will bend your rod eyes!
Old Nov 13, 2009 | 08:37 PM
qwikredline's Avatar
thats the issue.
Old Nov 14, 2009 | 10:03 AM
Black SS/SC 06's Avatar
Originally Posted by qwikredline
[/B]
thats the issue.
Good call
Old Nov 15, 2009 | 04:44 PM
TurboTommy's Avatar
Where did you find your straight spacers?
Old Nov 16, 2009 | 08:18 PM
tru2nrtt777's Avatar
This is definately sub'd Great Idea, I will be doing this to the balt soon and will report back about any DD or base model related issues.
Old Nov 16, 2009 | 08:28 PM
importkiller's Avatar
Due to the different suspension system on the TC would this still be a positive mod?
Old Nov 16, 2009 | 08:48 PM
Ruchus's Avatar
Great how to... Def doing this. My only concern is it catching on something because my care is lowered about 3 inches.This is a good mod for any car... Its all about getting the geometry right though. If your suspension is dropped or different from phatnackySS's the length could be different. A one inch drop wont make that much different but a 2.2 is like 3 inches higher than a car with after market springs...
Old Nov 16, 2009 | 10:29 PM
Do you have wheel hop?
Old Nov 16, 2009 | 10:37 PM
tglems's Avatar
Interesting. I may have to try this on my TC next time I go to the track. It gets nasty when I shift from 1->2.
Old Nov 17, 2009 | 12:08 AM
  #36
Not all of the time, If it is below 80 degrees outside then yes, but mostly that is the tires. If I rev high and launch I get wheel hop too.
Old Nov 17, 2009 | 06:39 PM
  #37
Originally Posted by LoveMyREDLINE
Im thinking the hankook tires i have now suck or the track just want prepped very well.
Probably track prep, my Hankooks are amazing.
I would say it would definately curb your high rpm wheel hop and if you use no-lift-shift between 1sth and 2nd it should help well there too.
Old Nov 17, 2009 | 07:12 PM
  #38
they were 1" spacers cut in half from ACE.
well befor i was running Kumho ECSTA SPT's that was UHP summer treadwear of 320 and they were great now im running hankook Ventus V4 ES H105 wich is a UHP all sesaon tire 430 tredwear. i got the i went with the h105s becasue i wasnt going to the track much and i needed somthing that would last (50 miles a day to/from work).
so its not that hankook is bad , its just the spts were so much better lol. Im thinking i might try heating them up alittle next time i go to the track.
Last edited by phatnackySS; Nov 17, 2009 at 07:12 PM. Reason: Automerged Doublepost
Old Nov 25, 2009 | 08:54 AM
  #39
TurboTommy's Avatar
Any more updates on how the traction bars are doing?
Old Nov 25, 2009 | 09:51 AM
  #40
no problems yet. i think alot of peoples issues may have been due to lack of proper lubrication. the bearings are metal to metal so you have to use a metal to metal lubricant like white lithium grease,and you have to keep them greased. But only the test of time will tell.
hacadacalopolis
Oct 28, 2015 06:09 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
