control arm bushings tool
Old 08-25-2018, 08:56 AM
b9k
b9k's Avatar
Hi,
Can I remove and replace bushings in the lower control arms with a tool like
Amazon Amazon
I'm guessing yes?
Asking before I spend $100, maybe there is a cheaper and/or better tool?
Old 08-25-2018, 09:00 AM
You're going to fight to get the rear cabs out. I tired one and was not successful for the trailing cab, I ended up using a press to get it out and a new one pressed in. Iirc I used a 1.5" sch40 metal pipe coupler to press them out and in.
Old 08-25-2018, 09:05 AM
b9k
b9k's Avatar
Oh dang, **** just got real. How many tons do you think I need. I guess I can grab one at hobo freight.
Old 08-25-2018, 03:40 PM
It was a little ~5 ton press, didnt need anywhere need the full ability to get them out just more than I could get with the tool
b9k (08-26-2018)
Old 08-25-2018, 03:58 PM
exninja's Avatar
I used that tool borrowed from AutoZone to press them in. I was unsuccessful getting them out, so I cut them out. Need to be very careful not to cut the control arm when you do that, though.
b9k (08-26-2018)
Old 08-25-2018, 06:46 PM
That probably what I'm going to do if I can't find a shop to press them out and the new ones in
Old 08-25-2018, 08:36 PM
63 Nova SS's Avatar
Have a shop do it. If you are off just a little it will remove alum material and the arm is junk unless you know someone who is good a tug welding. Trust me I did it.
b9k (08-26-2018)
Old 08-25-2018, 11:17 PM
I did them on my white ss but back then I had access to all the tools I could need not anymore I'll see if I can find a shop to do them for cheap
b9k (08-26-2018)
Old 08-26-2018, 06:49 AM
63 Nova SS's Avatar
There have been some that have gotten it done for $20-25. I used our big press at work and was installing Powell's mounts which are really stout. When I 1st started one of the cabs I got it just slightly crooked and as I pressed it in it removed just enough alum to make it move when I was wot. At the drag strip I noticed the car dart one way off the line. When I got home I noticed that the cab had started to work out of the arm. I had to get a new arm.
b9k (08-26-2018)
Old 08-26-2018, 12:39 PM
b9k
b9k's Avatar
alright, i'll find a machine shop then. thanks
Old 08-29-2018, 05:19 PM
b9k
b9k's Avatar
Everybody I called wanted like $100-150 to press each bushing.
Drove back to crateenginedepot and tom took care of me.
I have the new control arms with powell bushings installed and paid $150 for each control arm.
Old 08-29-2018, 05:28 PM
Wow really that sucks, hopefully I have better luck if not I'll go to Mexico to get it done
Old 08-29-2018, 05:41 PM
Tom is the man. Very helpful.
slipslapjack
How to Guide
07-15-2018 01:00 AM
Reedy17
10-23-2013 08:59 AM
DEZZIE41
12-20-2010 05:45 PM
2005CobaltLS
05-22-2009 02:51 PM
PatDamanCobalt
05-20-2008 09:05 AM
Quick Reply: control arm bushings tool
