front end humming noise?
im having a very annoying front end noise. its like a humming sound. wheel berings are good. i replaced the cv shafts cause i had a wobble upon accelerating and i thought it would help the sound. im on 215/40/18 bfg kdw's and k sport coilovers
Are you shure its not a wheel bearing, there is such a thing as new bad part. I dont no if u had them replaced recently. When ur driving and the noise happens turn the steering wheel side to side if the noise goes away or gets louder, u gotta bad bearing. Check your tires for abnormal wear such as cupping. Even a slightly cupped low pro tire can made alot of noise. Hope this helps.
