Help! Steering crunching/loose!
Old Aug 16, 2015 | 10:08 AM
Ardy's Avatar
Recently car has been on the downhill slope towards it's inevitable replacement but has recently developed a "crunching" sound when you're turning the wheel. It makes a crunching sound every time you turn the wheel. I've also noticed that where the steering was formally tight I now have quite some play in the wheel. Meaning I have to turn the wheel 30 degrees in either direction to get it to do just about anything.
Any thoughts as to what could cause this. Don't want to dump any kind of money into this, just need to know what I could be looking at.
Looking for replacements for it though, any suggestions?
Old Aug 16, 2015 | 10:31 AM
double clutch's Avatar
A crunching noise sounds like a broken clock spring, but that wouldnt affect your steering issues. The steering intermediate shaft or steering rack going bad can cause a sloppy steering wheel
Old Aug 16, 2015 | 10:59 AM
Ardy's Avatar
Broken clock spring, is that something to be worried about or is it fine for now?
As for the immediate shaft, is it something that would need immediate replacement or can I push it off while I look for a new vehicle.
Old Aug 20, 2015 | 09:12 AM
Ardy's Avatar
BUMP.
Still looking for options here. Any other thoughts? I have about a half turn of play (1/4 to left and 1/4 to right) before any kind of steering takes place.
Needs opinions!
Old Aug 20, 2015 | 11:00 AM
If u have that much play then i wouldnt be waiting to fix it. Take your drivers side wheel off and watch the intermediate shaft move the steering rack as someone else turns the steering wheel. You will be able to see what is making it so sloppy. You can also check the joint thats inside the car right above your feet
Old Aug 20, 2015 | 06:13 PM
LNFTX's Avatar
Sounds like a broken steering rack or an intermediate shaft with bad joints
Solaris99
28
Mar 15, 2017 01:22 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
TedSS
26
Oct 10, 2015 04:30 PM
importkiller
Sep 30, 2015 07:18 PM
