LSJ Rear Beam Axle - same as standard cobalt minus the stub axles?
Hi all,
I have a picture of a rear beam axle here from a standard cobalt SS. Basically I need just the metal bar that runs between the stub axles. Are all beam axles the same, minus the bolt on stub axles on both sides? Cant seem to find this information anywhere. |
as long as the axle beam has rear disk brakes, they are all the same. same bolt pattern and everything
Supposedly the welds are different thanks to our scientists here on css.net
Originally Posted by 07LSJ
(Post 6421828)
Originally Posted by Mini STSV
(Post 6421934)
But I should be able to take my spindles off my existing beam and bolt it up to a LS beam, correct?
Originally Posted by rustledjimmies
(Post 6421858)
Yeah, thats the situation Im in now. One side of the beam is bent, and they are like $500 used. Ive got LS beams here and my spindles and brakes are good. I just need the stupid beam part.
Here are pictures of the Beam axle from a 2.2 LS. But I have no clue what an SS looks like, as mine is under my car, immobilized.
http://i782.photobucket.com/albums/y...m/DSC07023.jpg http://i782.photobucket.com/albums/y...m/DSC07024.jpg http://i782.photobucket.com/albums/y...m/DSC07025.jpg http://i782.photobucket.com/albums/y...m/DSC07026.jpg http://i782.photobucket.com/albums/y...m/DSC07027.jpg http://i782.photobucket.com/albums/y...m/DSC07028.jpg http://i782.photobucket.com/albums/y...m/DSC07029.jpg |
how did you manage to twist a beam?
The LNF beam has a sway bar welded inside of it. I don't know if the LSJ one does or not, if so I don't know if the diameter is the same. That LS one seems to not have it, at least near as I can tell by the pictures.
All the cobalts have a rear sway bar but the ss ones are bigger, LNF's being the biggest from what I understand. I also read in another thread on here that the LNF one is not interchangeable with the other models. You really should find one with rear disc brakes though to make the swap as simple as possible
Also Mini STSV it would really be easier for us to help you if you put what kind of car you have into your garage or your signature.
all cobalt beams have a weld in bar. LNF is largest, LSJ next smaller as already detailed here, and the ls lt drum brake cars are smaller weld in still, without the ears welded on for rear disc calipers. I have a disc brake conversion plate for drum brake cars, at 235 + u supply disc brake parts.... Its pretty simple here, and most of the posters here have it right, add a genuine Powell hardcore bar to any of these beams and your handling will improve.
/end shameless plug.... http://i857.photobucket.com/albums/a...e/HPIM1174.jpghttp://i857.photobucket.com/albums/a...S/DSCN1317.jpg |
Do you have any other pictures of the disc brake conversion plate? Couldnt I technically just bolt up my disc brakes to a drum brake rear beam?
No, drum brake beams don't have the ears for the two caliper bolts, thus the conversion plate.
yes, but the cost of $235 for a "disc brake conversion plate" would be more than the price difference between an LS and SS axle.
So is the only difference between the SS/SC and SS/TC rear axle the larger sway bar?
is there a pic of the "conversion plate"?
dont do pictures to facilitate copies, sorry. we do the engineering and research and provide the parts to make it easy, not free.
