more control arm woes
Old Sep 1, 2018 | 07:13 PM
b9k's Avatar
b9k
I'm trying to install these control arms.
I got the driver's side cradle trailing bolt out the control arm with my little 200ft lb impact.
Tried all my other bigger impacts on the passenger side, even borrowed my friends 1200ft lb impact and it still won't come off.
It won't even budge, darn bolt seems welded on...
Any trick I can try before dropping the cradle like john powell says to do?
Old Sep 1, 2018 | 07:14 PM
Lots of nut buster on the nut, you have to crawl into the engine bay to see them but they're accessible
Old Sep 1, 2018 | 07:46 PM
Wytchdctr's Avatar
I went with; PB blaster overnight, impact for a few, then a big freaking breaker bar, and then used the impact to get it the rest of the way off.
Old Sep 1, 2018 | 08:03 PM
b9k's Avatar
b9k
Couldn't find it at first and then I finally see this brown looking turd.
Sprayed it down really good, gonna keep spraying it every 2 hours and then try again tomorrow.
Old Sep 1, 2018 | 09:41 PM
b9k's Avatar
b9k
rigged up some tubing right above it, so now I can just spray right into the tube without trying to aim and it drips directly above it.
so much easier.
Old Sep 2, 2018 | 03:32 PM
b9k's Avatar
b9k
Got the driver side control arm installed, was super easy.
Still can't get the bolt off passenger side, dunno what to do besides give up.
I guess I will keep hitting it with pb blaster every day and drive it a bit and try again next week?
Old Sep 2, 2018 | 05:31 PM
Wytchdctr's Avatar
If the bolt is seized in the sleeve of the CAB - it is going to take some luck that the PB works its way down that far. I have seen posts that range from destroying the sleeve in the CAB (see video below) - to dropping the subframe so you have a hell of a lot of access to it.
Old Sep 2, 2018 | 07:23 PM
b9k's Avatar
b9k
I wish I have gotten that far. It's still in the frame, the bolt hasn't moved a micron. Also, I don't think it's seized in the cab at all.
Just got some pics and well I don't think it's gonna come out. Man, I want to drive my car today and tomorrow too
Old Sep 2, 2018 | 08:53 PM
63 Nova SS's Avatar
That's pretty rusty.
Old Sep 4, 2018 | 11:10 AM
You basically have to wedge something in there to prevent the nut from spinning. I ended up welding the cage nut to the body of the car on one of them I did. Other way is to pry down on the frame while youre impacting to keep tension on the nut.
Old Sep 4, 2018 | 07:24 PM
b9k's Avatar
b9k
thank all, the arm is installed, imma be sore for a month from using this beastly impact but I got a free trophy
Old Sep 4, 2018 | 08:09 PM
Wow that was really rusted
Old Sep 13, 2018 | 10:18 AM
MINIz guy's Avatar
I must've gotten really lucky. One of my control arm bolts looks like that upon removal, but didn't put up a fuss coming out.
Old Sep 13, 2018 | 05:07 PM
If you start with an impact sometimes you can get away with it.
Old Sep 13, 2018 | 08:58 PM
MINIz guy's Avatar
My big boy Milwaukee Fuel 1/2" impact did the trick I guess. It only met one bolt that wouldn't come out but the shop also couldn't get that same bolt out.
slipslapjack
How to Guide
Jul 15, 2018 01:00 AM
Powell Race Parts
Jun 7, 2018 10:51 PM
tomj77
May 10, 2014 10:19 PM
rockstarbass1
Apr 12, 2010 09:35 AM
desperado
Aug 20, 2009 01:34 PM
