Need Wheel Spacer Sticky
I have been searching all over this site and found that people have ordered wheel spacers but no information to specifics. Please try to answer every question so we can create a more informational sticky. Please post your:
Wheel Spacer Type:
Website bought:
Thickness:
Hub or Wheel Centric?
Replaced studs?:
What stud length:
Lugs Stock or Aftermarket?:
Lug Type:
Website bought:
Rims Stock or Aftermarket?:
Offset:
Please post a pic with this and I will get a sticky created. Thanks!!!!
Reserved
Reserved
Wheel Spacer Type:
Website bought:
Thickness:
Replaced studs?:
What stud length:
Lug Type:
Website bought:
Offset:
Reserved
Reserved
Front:
Wheel Spacer Type: 5x110 to 5x110 hub adapter
Website bought: ebay
Thickness: 1" or 24mm
Hub or Wheel Centric? 67.1mm hubcentric
Replaced studs?: yes
What stud length: autozone/napa studs with no nubs at the end basically
Lugs Stock or Aftermarket?: aftermarket
Lug Type: type x racing open ended lugs
Website bought: summit
Rims Stock or Aftermarket?: stock sstc (worked with sc too)
Offset:idk
Rear
Wheel Spacer Type: 5x110 spacer
Thickness: 12mm or 1/2"
Hub or Wheel Centric? Hub centric 67.1mm
What stud length: arp extended studs (from zzp)
Lugs Stock or Aftermarket?: same as fronts, aftermarket
Lug Type: open ended
Rims Stock or Aftermarket?: stock tc (works on sc too)
Offset: idk
ARE YOU RUBBIN? - a little in the rear over the right bumps, im lowered 1.5". Oh and on 225/40 tires. Could use a fender rolller
Offset:idk
Rear
Offset: idk
So I've bought all the parts and waiting on the wheel spacers. I will take pics and build this out further once I get everything dropped, spaced and rolling.
