NEW Suspension Parts
Recently we have been approached by a local performance company wanting us to carry some of their suspension components for the LSJ.
We thought we post up and get everyones opinions before we start selling. We will fully test and inspect all parts before selling them with the Rebel seal of approval. On the side note, our website has been fixed and fully functional, please take a look and let us know if you want anything added or you find something wrong. Thanks www.rebelautoworxs.com TWIN LOWER SUBFRAME BAR One of the newest products is the lower subframe bar, it bolts under the LSJ's front end. The bar is bolted to the frame where the stock A-arm bolts purtrude. Supplied are 4 high strength bolts that replace the stock LSJ A-arm bolts, they are longer, go through the frame and into the bar, and also four nylock nuts that hold the bar in place. NO modifications are needed to mount this part. Made with 1/4" thick steel mounting plates, and 1" wide schedule 40 piping for the bars. Colour of the part is either black or primer (for colour matching purposes). Price of a single bar is $130CDN Group Buy Price of $120CDN http://www.rebelautoworxs.com/Pictur...port%20004.jpg http://www.rebelautoworxs.com/Pictur...port%20006.jpg SWAY BAR END LINKS Much thicker and stronger than stock, using heim joints welded one piece units. Supplied in this kit is Two endlinks, 1/2" bolts, spacers, and nylock nuts. The only modification needed to mount this part is the bolt hole on the strut needs to be bored/drilled out to 1/2" (it is made for 12mm, where the 1/2 bolt is 12.54mm, but the swaybar is allready drilled at 1/2", which makes the stock unit alittle sloppy in the hole). Again colour will be black or primer. Price of set $150CDN Group Buy Prices $130CDN http://www.rebelautoworxs.com/Pictur...inks%20001.jpg http://www.rebelautoworxs.com/Pictur...inks%20003.jpg REAR SUSPENSION BAR The bar connects between the rear trailing arms, making the rear suspension more rigid and transfers weight front left to right in a corner. This does not replace a rear sway bar but adds to the rigidity of the rear end. Unit is adjustable, this is the only way to put possitive camber on the rear wheels. Supplied in the kit is the bar, and bolts to attach it to the rear suspension. This kit does require stock holes to be drilled out to install the kit. Colour will be black or primer. Price of a single bar $90CDN Group Buy Price $85CDN http://www.rebelautoworxs.com/Pictures/Bars%20014.jpg http://www.rebelautoworxs.com/Pictures/Bars%20012.jpg TRACTION BARS Supplied bars are Aluminum, with heim joints, and all the bolts/fasteners to install the kit. This kit will require holes being bored/drilled out, easy installation. 04 ION's need a 1/8" hole in the control arm to be drilled out to 5/8", later models will need a little reaming, but not major hole drilling like the 04's, the subframe needs reaming for all years. These bars WILL cause creaking, clunking in the front end, this is normal since the kit hard bolts the suspension arm to the frame. Currently the only colour is Red anodized. Price of the kit is $180CDN Group Buy Price $160CDN http://www.rebelautoworxs.com/Pictures/Bars%20008.jpg http://www.rebelautoworxs.com/Pictures/Bars%20003.jpg |
Looks like some nice stuff :twothumbs
Too bad the traction bars cause creaking and stuff.
TWIN LOWER SUBFRAME BAR!!!
I want one!! |
sweet, im watching this...
What would the purpose be of the twin lower subframe bar?
Stiffen up the chassis a bit
The Subframe Bar fit the 2.2???
there are reviews of all this stuff on red line forums.com
I would assume most of this will be usable on all models, of course Rebel will have to test to be sure.
I'll test the subframe bar on my car :)
awesomeness
Shit ill test it all on mine =P
sweet....too bad I am taking parts off the car now haha
Originally Posted by damien
(Post 1664995)
mine used to shift and make noise until I hit the bolts with an impact wrench and now they are quiet as can be. good job for coppertop too for making business moves :thumb: |
Subframe will be a must to compliment my set-up!! thanks Rebel
love the twin lower subframe bar.........now all u need is subframe connectors.....ftw
That 1st thing I'll probably hop on. And maybe the trac bars. Looks good in red
I'm in for the twin lower subframe bar
If you guys want to see GB on this stuff, post up interest
I'd go for a GB on the sway bar links.
GB on the twin lower subframe bar
Originally Posted by REIGN SS
(Post 1665063)
GB on the twin lower subframe bar!! Just include a shipped price to the U.S.
if these traction bars don't make alot of nosie like others i might wanna get in on them
