View Poll Results: Help me out here!
Twin Subframe Bar
25.00%
Front Reinforment Strut Bar
31.25%
Rear Sway Bar
43.75%
Voters: 16. You may not vote on this poll
Which one first?
Old May 23, 2008 | 11:37 PM
MadBrad's Avatar
Which one first?
1. Twin Subframe Bar: RebelAutoWorxs Group Buy Price of $120CDN
2. ARK Front Reinforment Strut Bar: CSS member Price : $ 85.00 + 19.00 S/H US Continental.
3. Turbo Tech Racing Rear Sway Bar 1" (25.4MM) Cobalt 2005-08 Saturn Redline 2004-07 HHR: $159.99-$20.00 for rewards points.
http://www.turbotechracing.com/produ...idproduct=5148
Old May 23, 2008 | 11:38 PM
Projekt's Avatar
strut bar...easiest to install..cheapest...and has good improvement..+ its a GB right now..get it well its cheap!
Old May 23, 2008 | 11:50 PM
MadBrad's Avatar
bump. please
looking to buy tommorrow
Old May 23, 2008 | 11:56 PM
XgunsmokeX's Avatar
where does that twin bar bolt up???? work on a 2.2 auto
Old May 23, 2008 | 11:58 PM
MadBrad's Avatar
THIS PRODUCT FITS THE 2.0L, 2.4L AND 2.2L manual tranny's
TWIN LOWER SUBFRAME BAR
One of the newest products is the lower subframe bar, it bolts under the LSJ's front end. The bar is bolted to the frame where the stock A-arm bolts purtrude.
Supplied are 4 high strength bolts that replace the stock LSJ A-arm bolts,
they are longer, go through the frame and into the bar, and also four nylock
nuts that hold the bar in place. NO modifications are needed to mount this
part. Made with 1/4" thick steel mounting plates, and 1" wide schedule 40
piping for the bars.
Old May 23, 2008 | 11:59 PM
KillerBee's Avatar
rear sway bar
Old May 24, 2008 | 01:13 AM
MadBrad's Avatar
night bump
Old May 24, 2008 | 10:40 AM
MadBrad's Avatar
morning bump
Old May 24, 2008 | 02:03 PM
TurboTechRacing's Avatar
That strut bar is ARK? It looks 100% the same as the DC Sports, just painted red? Welds/brackets ect are 100% the same as the DC Sports bar...
Old May 24, 2008 | 02:16 PM
rallyracer's Avatar
x2...thats what I kept thinking.
Old May 24, 2008 | 02:43 PM
Switt23's Avatar
They said due to the layout and design of the engine bay (the firewall is smashed into the strut mounts) there is little room to design a better bar for cheaper. So they made the bar for the effiecent cost. If that makes sense.
Then it's the ARK orange-red color.
I say rear sway-bar. You won't see lots of improvement from the strut bars until your throw down enough force to get the frame to tweak
