Service Traction/ESC Off/ABS Light
Well, I installed CM springs this weekend and on my way home my ABS light and Traction light came on, along with my ABS light. I tried pulling my battery to see if it was stuck but its still on. I am going to check the ABS sensor on each wheel when I get home, but I dont know what to do about the Traction/ESC. Any suggestions?
Bumping an old thread instead of making a new one...I'm having the same problem but mine are plugged in. Got it scanned and said bad wheels speed sensor left front and left rear. Bought some used replacements on ebay. Lights are still on. No noticeable problems with the wires. Any ideas? Maybe my replacements are bad too? Any help would be appreciated.
Same problem here. Gonna jack up the car later and check it out. Buddy of mine read the code and it looms like a bad sensor on the front passenger side. Just replaced the hub too... Grrrr
Looks like it was just a bad sensor in the hub... Replaced it and everything is running fine. No relearn necessary since you can't reset it using code reader. It reset itself.
importkiller
09-30-2015 07:18 PM
z28addiction
09-28-2015 12:03 AM
