06 pursuit gt sedan.. ABS on Hub Bearing Disable Question...
Hey, i have a Hub Bearing ABS Sensor failing... can i just pull the fuse for ABS and disable the ABS when i come to a stop at 2-4 km/h so the abs doesn't doing its abs skipping motion for no reason, my Hubs are still good bearing wise.. also will this put an ABS light on dash. ?
06pursuitgtsedan (10-23-2017)
Ya i'm going to get which wheel bearing is bad and get it fixed.. thinking doing moog's if fronts which believe it is.. and get two.. also doing steering shaft and rack.. with new outer tie rods.
