Coils binding
Coils binding
Anyone here on coilovers? Small issue when turning specifically on the passenger side. It sounds like the actual coils popping rather than the axles binding...will try raising them an inch at a time but any input would be great
I can’t remember if we pre loaded them or not. We swapped my rear axle assembly at the same time so I was pretty tired lol. Maybe I’ll do that and see what happens first
Originally Posted by royce777
you shouldn't have to adjust the preload. unless you messed with the spring and upper locking rings. the height adjustment is on the lower knuckle piece.
Not sure what the pivot part is called at the top of the coil but all I did was grease it and it’s fine now lol. For some reason there was a bit of movement causing it to sound like the coil was popping
