Steering wheel shake
Have a 06 as/sc, no major problems. I have noticed the last week or so that when I get the car above 40 mph the steering wheel shakes, and the faster the more violent the shaking. Only took a quick glance without taking the tires off, any thoughts what could be the problem?
First things first, check your tire balance.
Originally Posted by nobody2u
(Post 6886377)
^ as said, check balance. i would try to rotate the tires front to rear and see if it changes before you spend money on a balance. also check to see if the ball joints or tie rods are loose
I posted this right before work and at work I was thinking that I may have thrown a weight, I'm definitely going to check that tomorrow. Don't think it's a tierod or ball joint or the shake would happen the whole time.
I also just had my tires rotated about 2 weeks ago, could be maybe a rear tire threw a weight sometime ago and when I rotated the tires to the front now I'm feeling it. If it is a weight, can I just pick one up at autozone? And if so what's the weight to look for? |
is there snow on the inside of your rims? Sounds silly but a lot of people dont think of it
wheel bearings?
Originally Posted by Kingpin2010
(Post 6887490)
Originally Posted by Sox-Fan
(Post 6887518)
wheel bearings?
since balancing wheels was said. does it stop shaking past 40mph? if so you have unbalanced wheels..
and these are all FWD cars. it could be a problem with the drivetrain |
It definetely could be a wheel out of balance. I wouldn't go to Walmart though, I tossed the weights they put on after 1 autox and about 500 miles. Could also be a very slight miss alignment on one side. Wouldn't be a wheel bearing, that causes play in the vertical direction not lateral.
Went and checked the front wheels and low and behold I threw half the weights on the left front wheel. Glad it's just that, easy and cheap fix.
Ill be heading to the dealership my brother works at to get the wheels balanced. Trust them a whole lot more than wal-mart |
X1,000,000 on [not going to] Wal-Mart.
^ this, i wouldnt buy TP there
Hate to revive old thread but its needed.
Anyway I ended up getting a tire balance, and the shaking seemed to have stopped, but as the weeks have gone on its came back. Once I get to around 40 the steering wheel shakes. The wheel is also now pulling to the left. We think I may have a crack in my wheel, haven't had time to check yet. Thoughts? |
(Post 6964812)
Originally Posted by AaronJ
(Post 6964867)
Not a cracked wheel, I'm assuming you'd be slowly losing air if this were the case, but I bet you have a bent wheel. If it's bent and becoming unbalanced again, the wheel is probably throwing off its weights.
(Post 6964883)
Well we think it could be cracked top because I have been dealing with a slow leak too. Just seeing if its not something else before I decide to buy a new wheel.
Originally Posted by Whitnith
(Post 6964891)
You are going to take the tire off and check it out before buying a new one, right?
