Suspension gurus chime in and help me out!
Started doing this a few days ago.. Does this when turning the wheel.. When starting off in first gear makes a few knocks/clunks/... When driving in 1st 2nd, or 3rd low Rpms, and press the brake once it makes a knock or clunk.
What do you guys think? http://i1017.photobucket.com/albums/...3A0CE0CC94.mp4 |
sounds like..... someone is trying to make love to the car :lol:
but seriously im not too sure |
imma go with cv joint as powell said, and to my knowledge it wont make noise all the time, my gf's celica has a bad cv joint, and it only makes noise every once and a while, you could also check your sway bar endlinks, grab them and jerk em around, if they have any give, they are bad; i think thats how you check them, someone correct me if im wrong.
Checked a bunch of shit everything is gooood
Hmmm definitely doesn't sound like a cv joint
its the top bearing on the strut mount or you have bad coilovers. either way, jack it up and get it apart and fixed lol steering is vip
(Post 6643444)
Originally Posted by seeyaass
(Post 6643661)
+1. And Powell I'll check this out tomorrow when I turn the wheel.. The strut top joint swivels very smoothly doesent jump get stuck or anything
Loose Lugs? Happened to me once and sounded similar...
Everything seemed fine on the coils Powell. If it was the top strut bearing I would definitely feel it if I put my hand on the strut top correct? Lugs are tightened.
check the lower bracket. check the spring perch. have some one turn the wheel while you look at the spring with a flashlight thru the wheel to see if the spring is binding and unwinding on the lower or upper spring perch.
all i got so far if the top plate is good. all the best of luck with this. hope u find the answer. |
Okay I will do that. Lower brackets are tightened. I'll check the spring. Can't wait to find out what this is!
Slight wobble upon braking while driving on the highway.. Another symptom lol.. Anyone think it would be a wheel bearing?
