Axle bind check up
Old 02-27-2015, 09:34 AM
Joebam1217's Avatar
Axle bind check up
So I got my car balanced and alligned. Pretty much got rid of all the vibrations that I said I had in the previous post. The only weird thing is, when I turn the wheel all the way (rarely does this happen) it should a like a cracking/rubbing noise. I can't remeber if It did it before I lowered it or not. Is this axle bind or just something else? Should I be concerned or should it be fine? I'm lowered 2 inches by eibach sportlines
Old 02-27-2015, 10:04 AM
Sl0wbaltSS's Avatar
I'm lowered on same springs, if I turn it all the way and go forward it sounds like I have straight cut gears. rubbing ftw.
Old 02-27-2015, 10:21 AM
Joebam1217's Avatar
So is it a bad thing?
turbochargedss2012
09-20-2023 12:17 PM
biniecki
10-25-2015 02:23 PM
brandon04
10-21-2015 07:04 AM
DANRICKARD
10-01-2015 12:08 AM
yellow dragon
09-28-2015 09:49 PM
Quick Reply: Axle bind check up
