31L/100 km mileage
Hi - so the engine is in the car now and it's running, but the mileage is 31 L per 100 km, which means something is really wrong.
A few possibilities: O2 sensor Air leak in manifold MAF or MAP sensor Any suggestions? Any checks you can suggest? Thanks, O6B |
Gonna start with the basics, do you have any codes?
I'm on the mobile app so I dont see sigs what cobalt/g5 do you have? |
The gas mileage showing in the display is now showing the right mileage about 7-8 L/100 Km.
Scan it. We can't help you but obviously something's wrong
Yes when I shift gears, the throttle stays open and high - I'll scan it in the morning and post it - it'll be easier with daylight. Thanks for the hand.
Code scan p0068 p0106 p106P p0480. I'll check for vacuum leaks now.
Originally Posted by OhSixBalt
(Post 7702544)
Replaced MAF and still the RPM rises in between shifts. Codes 480 and 833 - Any ideas? :cssNET: |
Here's a solution path from website http://ricksfreeautorepairadvice.com/p0480-cobalt-fix/Fix code P0480 on Cobalt
This vehicle has a 2-speed cooling fan. If you run into the P0480 code and find that the fan will only run on the highest speed, start by checking for a blown cooling fan fuse #1 in the underhood fuse block. If that’s ok, swap cooling fan relay #1 with the high speed cooling fan relay #2. Both relays have the same part number. Rest the PCM to clear the trouble code and drive the vehicle. If the low speed relay is bad, the swap will result in a new code, P0481. That will confirm that the relay is bad. Replace the low speed relay. However, if the P0480 returns with the relays in their swapped positions, check the wiring harness for an open condition. Check the continuity of the dark green wire from the #1 cooling fan relay to the PCM, pin #47 © 2012 Rick Muscoplat Source 480 Code solution |
So I did the swap and 480 returned, so now I'll inspect the green wire to PCM pin #47
