hpt tuner needed in peoria il area please help
I need a hpt tuner that can help me in peoria il area
I own a car audio shop wouldnt mind trading for services my car is cutting off at high rpm says engine reduced power and idle is aradic and seems like im burning a ton of gas latly. I replaced my throttle body 2 days ago and i think i did the idle relearn properly to no avail. Please help. by the way my BCM went out so im waiting on a replacement to come in the mail thanks to a cobaltss.net user thank you again any suggestions thanks in advance |
You can bring the car up to us at performance autowerks..... It's far but we will get you handled
That is a long drive with a broken car lol
Are you sure you know what the problem is? Is it something you have run into before ? How much you thinking it will run me based on your assumptions ? can you program the new BCM if I bring it ? |
I'm not 100% sure but between my boss and I we have years of experience in cars in general and have felt with the lnf specifically since 07 in the solstice and sky.we can reprogram Ecus and bcms . We are not a vendor here so I cannot disclose pricinga so pm me. We charge 1.5 hours for diagnostics flat fee for as long as diagnostics take not per hour
With no power steering , cant read odometer , fuel range says low all the time.
I have a new BCM coming does that sound like a solution to the problem ? |
| All times are GMT -4. The time now is 02:23 AM. |
