LDK Opel Tuning Issues
Posting here cause why not,
I'm an LDK swapped LNF car. Been tuning for about 3 months now with a reputable tuner but can't get past a weird issue. For starters, I'm stock clutch, stock flywheel, OTTP front and rear trans mounts, stock motor and top trans mounts, stock turbo full bolt on. I've seen logs from cars with different setups and they all have the same problem; Low load, low rpm knock retard. I ran GMS1 tune from my LNF on this car to break it in. When I noticed knock retard on the Aeroforce gauge I got hptuners and got in contact with a tuner. Even he's shocked by the knock retard and the fact that through injector constant, pressure adder, pulse corrections, injector spray angle, even timing and optimal torque tables; it still exists. I'm here wondering if there's anything that anyone can suggest (I'd hope with proof of it working) to look into. The tune has been reduced to GMS1 with injector constant, pressure adder, pulse corrections changed, as well as MALT. DALS (Torque to Load) is regular GMS1. And it still exists. Anyone LDK swapped (with Opels) able to get rid of the low load low rpm knock retard? Looking at the graph of Airload % and RPM the KR exists between 20-120% Airload and 800-4000rpm and is usually found when letting off the clutch from a red light. It has 0 issues in WOT. |
Sounds like maybe LSPI issue? Did you switch to a different oil since your last engine or something?
Does it pull ignition timing with the KR?
The KR could be from various tables not aligning correctly as the ECU expects. If it doesn't pull timing during the KR a number of the tables could use some fine-tuning. Injector angle usually can reduce the false KR, but sometimes it's a bad sensor or loose sensor. |
(Post 7708356)
Originally Posted by ECaulk
(Post 7708360)
Still having this issue, anyone LDK swapped with K04, LDK manifold, and rotated mounts and have any clearance issues? Mine's right up against the brake line that crosses to the passenger side.
https://imgur.com/khfdr30 |
