LTFT always positive while cruising
#51
I think most of my wierd fuel trim issues has to do with the maf being dirty.i cleaned maf and my ltft is going the other direction with a almost steady -%
Not high but -3.9 highest.
Going to unplug battery and see what it does.
Rear o2 cel came on second start
#52
after driving a bunch the LTFT are definitely different without rear o2 plugged in. STFT seem the same. LTFT adjustments are roughly half of what they were with the rear o2 plugged in.
#57
https://photos.app.goo.gl/XNu7aB6PjbDtAGQC2
Seems clear that the rear o2 has an impact on at least ltft.
Back up to roughly double the adjustment with rear o2 plugged in
#64
the rear o2 is reading rich and the front o2 moves around a little bit.
at idle the rear occasionally moves around lean around stoich
the primary o2 reads back and forth but rich a lot of the time.
its all kinda a cluster ****. i need to buy hpt but wife doesn't want me to spend money on this car. i might be able to sneak it in sometime.
.7-.9 on the rear o2 while cruising, at idle it settles down .1-.6 mostly towards .6 tho
https://photos.app.goo.gl/h6Ee3RTfBMhUrp362
#73
the car seems to idle smoother, and part throttle seems smoother. i'm getting less of a exhaust smell. but i will give it some time to know for sure.
https://photos.app.goo.gl/zgxycf3rUuaeYuB33
MastaShaKe_88
24
09-24-2011 11:44 PM
SS_carnatic
07-25-2011 01:11 PM
samsumthing
02-18-2007 09:33 PM
