OCD + maf tuning = epic
Here is my maf tune cruising. This is what it should look like when done right and when you are ocd.
TVS 80s 2.8 pulley e85
http://www.mediafire.com/file/yw4dmjymnwy/2.8.hpl
Soo... your fuel trims are perfectly 0... What's the secret?
My LTFT is off in the tune, and my STFT's are +- 10-20 sometimes at idle even after many many logs with a wideband and adjusting the MAF (MAF only tune).
I've logged mine a ton, but it still won't get that close. The MAF scaling isn't 'accurate' enough get a perfect flow reading down low. How does your idle trims look? You using VE up until a certain RPM? Maybe that's my problem, I'm running MAF only for simplicity. My fuel trims (STFT) are whack even after a lot of logging and tuning. The car runs good and idles fine (although rather rich until warmed up), but my trims bounce a lot at idle and down low.
Intake skewing trims? Bad O2 sensor? Vac leak? Help! lol
Hmm. I kinda thought this too... But I'm not pro, I didn't wanna call it out..
The factory O2 doesn't switch much tho either so it seemed to be pretty steady state cruising tho, so I dunno...
The STFT's, though, will always change. They are constantly swinging and trimming to take up the slack for the ever changing environment in the intake system. Every time you see the O2 voltage swing off 850mv by more than 50mv, is a point where the STFT's should modify and swing to compensate.
If you'd have shown us a cruising + WOT log, with an AFR log (config attached) it would be something to show off... but this is just a steady state log with no feed back.
I just posted it because of the maf air fuel error. Its spot on like a good tune looks like. My wot is the same way within 0 and -1.
