P0300 - misfire on E85 LE5
Old Jun 19, 2013 | 07:57 PM
noorj's Avatar
Hey guys, so I recently swapped to 60's and E85 in preparation for the turbo I'm putting on. I spent a solid week getting the tune down good but now I'm getting a random misfire code. I'm thinking my injector settings might be off a little (they were given to me by a friend with a similar setup). I changed plugs and it still persists but I'm pretty sure my the logs it is only at idle. Any ideas?
Old Jun 19, 2013 | 08:01 PM
ThexGovenor's Avatar
Not sure how the 2.4 works but I know on the LSJ you want at least 80's for E85
Old Jun 19, 2013 | 08:25 PM
The injector size depends on how much air he plans on pushing.
Do you have a return style fuel system installed? (Pretty sure the fueling was the same as the l61 stock returnless) could also try bumping the idle up 100rpm and see if it settles out
Old Jun 19, 2013 | 09:15 PM
Well he said he is going turbo so depending on his boost level he might need the 80's
Old Jun 19, 2013 | 09:21 PM
noorj's Avatar
I should only be flowing around 30 lb/min so the 60's will be good. I'll try bumping up the idle to see if it helps
Old Jun 21, 2013 | 03:21 PM
keep us posted!
Old Jun 21, 2013 | 04:12 PM
nhanson's Avatar
I could send you my tune to compare to make sure 60s are setup correctly.
Is this at idle only?
Old Jun 21, 2013 | 10:45 PM
noorj's Avatar
Got it! Thanks for the responses guys, just had to keep tweaking the base running airflow and min pulse adder
Old Jun 25, 2013 | 10:50 PM
dtabbs's Avatar
Did you scale your tune? That is the only way to do this correctly.
I have mine scaled .76% with 60lbs.
Sean Cummings
Mar 9, 2018 12:26 AM
Builttss
Oct 4, 2015 10:21 AM
717ssbalt
Oct 2, 2015 04:01 PM
bobbob160
Sep 15, 2015 11:31 PM
Macgyver2484
Sep 2, 2015 05:44 PM
