What Rough Startup Idle with stock LNF PCM - to adjust with HP Tuners?
Any HP tuners on here? My car came with a locked Trifecta tuned PCM. I just recently swapped in a stock replacement PCM. After installing the stock PCM, my car has a very rough idle when you first start it when it’s cold. Almost like it’s cammed. After the 1st initial warm up it’s perfectly fine and idles smooth. I didn’t have this with the Trifecta tuned PCM. Being that PCM is locked, I am unable to pull the information from it to see what they had the settings for it. So I am wondering what should I try adjusting in the PCM to help with the cold startup? I have already HP tuned the car and its running great besides the startup idle.
09 SS/TC
HP Tuned @21psi
K&N SRI Intake
Hahn Upper IC pipe and Intercooler
Cat & Muffler Delete
Also should I just stick with 21 PSI or push it any farther? My car does not have the 3 bar sensor upgrade.
09 SS/TC
HP Tuned @21psi
K&N SRI Intake
Did you go through the LNF how-tos over on hptuners forum?
Because you need to do the MAF adjustments for the K&N
The cat warmup was actually already disabled in his tune. His cam phasing amongst a few other things were is main culprits. The car cold starts and idles like a gem now..
camaromanss1992
10-01-2015 10:51 PM
