Originally Posted by AjSS
(Post 1096868)
Yea, is there some way to take care of that with HP Tuners?
Oh, ok then. Thanks!
(Post 1091543)
Is there a way to disable the first O2 sensor with HP Tuners, and just use that bung for a wideband? I just got my NGK wideband today, and dont want to have an extra bung. Im going to go aftermarket eventually anyway.
(Post 1093842)
If I just disabled the CEL that would come up when there was no O2 sensor, and put my wideband in that bung, will it cause trouble?
Originally Posted by Doc
(Post 1098338)
A word of advice, the first O2 sensor is used for the computer to read the afr, its a rough one, but it's needed for the correct operation. I believe the NGK also has a narrowband output like the LC-1 has. Hopefully, otherwise you'll have to get another bung welded in pre-cat for the wideband.
Yeh, the NGK is only 0-5V.
Why not just get another bung welded in before the cat (where it should be). If you don't want to run it all the time, most come with a plug. Most shops should do it pretty cheap. Hey, DOC!! You're on the wrong coast! Gotta get back to the "right" coast soon, man! |
