PCV Check Valve option now avaliable on Turbo Tech Racing LNF Intake Manifolds.
PCV Check Valve option now available on Turbo Tech Racing LNF Intake Manifolds. :twothumbs
We have completed the upgrade cartridge kit option for our LNF intake manifolds. This option allows you to install your factory PCV check valve and maintain stock PCV functionality. (Check valve not included). Upgrade option includes: Check valve cartridge, lines, all connection fittings, and install instructions. In addition, the ability to filter the oil/air through a separator (not included). Not allowing engine oil to migrate to the intake valves, from the intake manifold PCV port. The current stock manifold would be nearly impossible to separate the oil/air, as the stock PCV valve/intake manifold is to intergraded, not allow an easy way to filter the oil out. http://www.turbotechracing.com/produ...036_detail.jpg http://www.turbotechracing.com/produ...399_detail.jpg http://www.turbotechracing.com/produ...017_detail.jpg |
You need to amend your post to add
"We have listened to your concerns and responded" :twothumbs good job. |
Originally Posted by Sox-Fan
(Post 6963933)
Dick? I was complimenting him. That a problem for you?
(Post 6963933)
I have no clue what exactly this does or what a check valve is, il pass lol
Originally Posted by mrbelvedere
(Post 6964306)
well then you shouldn't have told him that he needed to amend his post that is being a dick you should have said good job etc.
Out of respect for him I won't continue to address your remarks here. I think They are entirely out of place and unnecessary. |
so powells kit is nearly impossible on the stock manifold?
Originally Posted by cranemaster
(Post 6964310)
Originally Posted by Chevy_tuner
(Post 6964316)
Thanks to mrbelvedere and sox-fan for your support.
Can you add this to a old style manifold or can i send my old one in? My intake is still nib.
Originally Posted by Gunney_07
(Post 6964648)
can you send me a link to purchase this seperate from the manifold
(Post 6964661)
2 Attachment(s)
(Post 6964316)
The migration of oil in the intake comes from the dirty side of the PCV system, entering through the impeller side of the turbo. The Powell PCV upgrade takes care of that. Nonetheless we have been sent a TTR manifold to retrofit the stock PCV valve. The retrofit we have done includes a stock PCV valve, and the machined part has the same, correct port sizes the stock Inlet manifold has. The retrofit is for PCV purposes only. This retrofit costs about $125.00 including the valve, but not including the cost of re Powder coating the manifold, or shipping costs. Attachment 42054 I am sure the customer will be happy to post pictures of the completed assembly on his car. Attachment 42055 |
Nice work John. What you offer is something that members most likely could not do in their garage; as to why we did the cartridge option.
However on future TTR manifolds we have already spoken about making an intergrated option as you show. However cost would be higher than the current cartridge option (just like you are charging more than our option), with little or less benifit. Our cartridge option is only $59.99 when purchase at the same time as a TTR Manifold, or $69.99 when purchase at a later date. We also have noticed that oil does come through the front PCV valve into the intake manifold. As much as the rear PCV? No. But it still does have some. We are already working on offering our cartridge system to be intergrated into an oil/air seperator, to completely remove any possible chance of engine oil on the valves. Never the less good job on the retrofit. |
(Post 6964316)
are there any pictures of this installed?
1 Attachment(s)
Attachment 40631
Here is a picture the customer sent me with it installed. I am sad for him. My job was to fix the PCV issue, and that was done. But now he has installed it, its clear this manifold does not have the anchor points of the stock part. The dipstick has no anchor point anymore. That can be rigged with tie wraps, I supposed. But the HPFP line and regulator, has no provision to be secured properly. If you have one of these things please anchor the HPFP line properly. |
I guess, this also important for L61 engines ? How could it be managed in that case as the places are different?
Nice job to All.
pic of it on the car?
^look three posts above
