Lsj misc
Looking for the stock "T" filler for the intercooler pump and also looking for the idler pulley and stand, stock size please.
Supercharging a base and I think this is all I have left to get. Maybe a phenolic spacer if I can find one cheap enough before black Friday. This would be shipped to 75605, Longview,Tx |
I'd recommend sourcing an Opt. B reservoir since you are doing a new install instead of the stock T filler. Easier to bleed air bubbles out. Alternatively you can go on the cheap and just use a regular 3/4" hose Tee and just run a short length of hose up to fill through with a funnel then plug it off when you're done.
Are you looking for the tensioner pulley assembly or the idler pulley assembly? |
Originally Posted by jdbaugh1
(Post 7720939)
Are you looking for the tensioner pulley assembly or the idler pulley assembly? Good point. I forgot the option b was easier to bleed. I guess id need the stock heat exchanger for that also. Was just planning on using a cobra. |
Originally Posted by goaliemo
(Post 7721002)
Tensioner pulley. The spring loaded one.
True. I did find the t filler thing. I think imma scratch it and just do the tank like you said. Easier to mess with.
(Post 7721064)
https://cimg1.ibsrv.net/gimg/www.cob...56eb34aeec.jpg |
(Post 7721066)
You can always add a vent at a high spot in the system if you feel like it as well. For mine I drilled and tapped the upper passenger side of the intake manifold coolant passage.
(Post 7721140)
Do you have more pics? Thats a Damn good idea
