16psi + C16 + 150shot + 22* timing = Z06 Killer :-)
*EDIT FOR THE WHINERS*
My mod/setting list is as follows: 245/45R17 Nitto NT555R Drag Radials (no rubbing) 17 x 8 +40mm Konig Again 5 wheels Custom made 3" cold ar intake Pacesetter header Hollowed cat SPEC Stage 4 clutch Stock refinished flywheel Stock M62 supercharger ---The blower is not ported. The snout is not machined. Cobra heat exchanger ---No dual pass, no option b, just the HE. Intense 2.7" pulley and hub Stock throttle body NGK BKR7E plugs gapped at .030" HP Tuners so I can adjust shit on the fly VP Fuel C16 Race Gas ---The C16 lets me run 22 degrees of timing on the bottle and 27 degrees off the bottle with NO knock. NOS Sniper Kit with 10 lb bottle 150 wet shot of nitrous B+G Springs B&M Shifter STOCK EXHAUST FROM THE CAT BACK. IDK HOW MANY OF YOU I HAVE TO TELL THAT YOU DO NOT NEED TO CHANGE YOUR EXHAUST FOR THIS CAR. 100% STOCK MOTOR. HEAD, VALVETRAIN, BLOCK, EVERYTHING IS STOCK. 100% FULL INTERIOR. */EDIT FOT THE WHINERS* My friend Scott has a 2003 Z06 6-speed and a bunch of us are always out screwing around. His car did something to the tune of 460whp on the last dyno day we had and it is QUICK. Even a 600+whp Cobra can barely beat him. So a couple nights ago we were out screwing around and I decided to go all out with the Redline since this is the last weekend on the blower before the turbo goes on. Here are the results. First race both in second gear at about 40mph and of course the drag radials on my car just roast off and he's ahead of me by like two cars already and I had to let off. The brand new SPEC stage 4 was slipping already in this race, but once it slipped that one time bad it didn't really let go again all night. http://www.youtube.com/watch?v=5xtgTFrOVFM This is the GOOD race. We both were at about 50mph in third gear. I honked and admittedly took a slight jump on him and we just kept going to about 150 or so before we let off. Check the white lines in the road lol. http://www.youtube.com/watch?v=stTitcf4jRM |
click
wow very nice... wish I could be doing that right now...
Was not expecting that.. Lol.. !! Nice
... cool vid...
Unfortunately the nay-sayers are gonna be in here soon.... |
what are your other mods? we have very much the same set-up ...16-17 psi, 22* timing...im only running the 50 tho...
Originally Posted by Omega_5
(Post 2626972)
... cool vid...
Unfortunately the nay-sayers are gonna be in here soon.... To the thread starter, I wouldn't let these results go to your head thinking you have a 'ZO6 killer'.. :nono: |
It almost seems as though he is not on it that much at all in the second race. Nice redline though. Looks clean.
how "brand new" is your spec?
im hoping youve given it a break in..... otherwise its not surprising that its slipping |
so you have a 450 whp redline, that no one has ever heard of?? lol
Originally Posted by SuperchargedSS
(Post 2627536)
ok so they raced again and the vette started in the wrong gear... wich would give the ion a bit of a head start but then wouldnt the vette start to walk by him as soon as the ion shifted, unless the ion is pushing some serious hp
Originally Posted by Blacknite
(Post 2627599)
because its in the wrong gear. Even in my car... 50mph is a 2nd gear affair
Originally Posted by lsjwannabe
(Post 2627631)
they were both in third gear. Our second ends at 80
2nd gear
6500 -> 70 7000 -> 76 7500 -> 80 Ok... bye now. |
(Post 2627834)
2nd gear
Originally Posted by 0redline6
(Post 2627750)
It ends at 60
WTF are you talking about? I take 2nd to about 80. I'm on a 25.7" (245/45R17 Nitto 555R) tire with no rubbing BTW. Shit third will go clear to about 120 and I know 4th will go to about 155 or so according to HP Tuners. 5th should be good for right about 200. Put some bigger tires on your car and make your life easier on the amount of shifting you do. You can go an inch taller and an inch wider than stock with no rubbing at all. And we were starting in third because the clutch was slipping on the 2-3 upshift in my car for some reason, but it would hold just fine in third. He started in third because we were going to go from about 60, but ended up honking at 50. Regardless...he never caught up you know? If you all want to see me running 11s, come to PRP in Pittsburgh, PA Wednesday night. :) |
Originally Posted by StreetDreamz
(Post 2627877)
7300 is not 7500, and with taller tires you def have more mph in each gear.
I'll be up at PRP on wednesday. I wanna see this man.
(Post 2627894)
i have the max size i can put on my rims.. and 65 is what it goes to. on a 2.7inch pulley... idk if there is any diffrence in maybe tire pressure or elivation but thats what i shit at 65.. which is when the light on my ladder tach flashes red at 7300 rpms
And if the Vette and the Saturn both start in the same gear, at the same speed, and are able to go to the same speed in the same gear...then wouldn't you consider that a pretty even race? |
(Post 2627860)
i rev to like 7300 and it ends at 65
(Post 2627877)
(Post 2628022)
You have the max size? So you should be running a 245/45R17 or 235/50R17 or so. Believe me, a 1" tire difference makes about a 4% difference which will affect your speedo by about 2.5mph at 60mph and as you go faster it throws it off more. TRUST US man, we run our cars hard. If I say I'm shifting at 80mph in 2nd at 7500rpm, you can bet your sweet ass that's what I'm doing.
That's all I have to add. |
(Post 2627338)
You are right... Here is the first! Why would the vette be in 3rd gear going 50mph? Think about it.. he is in 2nd gear (bottom of 2nd because those gears are LONG) when they go from 40mph, but then is in 3rd gear going only 10mph faster??!!
To the thread starter, I wouldn't let these results go to your head thinking you have a 'ZO6 killer'.. :nono: A Z06 does 62mph in first gear so starting in 3rd from a 50 roll is dumb. Hell even with the Z51 geared T-56 I start in second from a 45-50mph roll. I am pretty sure the OP's car will not run high 10's low 11's so a Z06 killer it is not. |
Originally Posted by LS2guy
(Post 2629246)
