Can't Find TIRE LEARN through DIC reset and Trouble with TPMS.
So I have read EVERYWHERE on how to Reset my TPMS sensors. I tried doing it with my remote (Hold Down LOCK/UNLOCK). That didn't work because I was for 2 mins. draining air and putting it back waiting for the car to beep at me on the driver side when the turn signal came on. The only beeping noise I get is when The Sensors Don't register in Time.
I Even used the method of holding down the INFO/DIC button and the Oil Life Reset comes up and as I scroll through NO TIRE LEARN shows up. So is there something I am doing wrong or is my car computer getting old that I need go to the Deal or Other Tire Place (Pep Boys, Just Tires, etc) and get it fixed. The Sensors work fine and this was after I rotated my tires. Front Left reads at Rear Left and Front Right reads as Rear Right and then the other way round.
I did that and Like I said I was on the driver side and taking out and putting back air and the sensor never picked up..
If you did the procedure correctly as stated above then you have a bad sensor. If you have a bad sensor it will not let you skip it or reset tpms the light will stay on until you get the sensor fixed and cycle all the way thru the reset
I am going to try and let the air out slowly for 5-10 seconds and then see what happens..
and thanks for the help I will be back later to tell you what happen
The Sensors work...I put air in and it tells me the PSI of the Tire unless your talking about something else with the sensor...
Yes as long as you got the right MHz sensor it will learn with normal procedure
