Changing Wheels
Changing Wheels
I have a 2009 Cobalt SS sedan and I am thinking of upgrading wheels. I know the lug pattern is 5x110 and I plan to run 18" wheels. Any suggestions on what wheels will work with the Brembo brakes?
check out the wheel thread on here. i have some msr wheels and i use a 3mm up front to clear the brembos. depends what the offset is for the wheels. 5x110 is limited to what you can find.
Update
So after getting the tires mounted on the wheels attempted to mount the wheels to the car and guess what brembos do not clear in the front life sucks.
Update
I did not try using a spacer, also I went with 235 40-18 Federal 595 tires. The wheels are 18x8.5 +30. What size spacer do I need to be able to clear the brembos?
