Changing Wheels
I have a 2009 Cobalt SS sedan and I am thinking of upgrading wheels. I know the lug pattern is 5x110 and I plan to run 18" wheels. Any suggestions on what wheels will work with the Brembo brakes?https://cimg4.ibsrv.net/gimg/www.cob...f461d119d7.jpg
check out the wheel thread on here. i have some msr wheels and i use a 3mm up front to clear the brembos. depends what the offset is for the wheels. 5x110 is limited to what you can find.
there are actually more options than most ppl think. Typical wheel of choice for cobalt owners ins Varrstoens.
I like my enkei m52 wheels
Originally Posted by royce777
(Post 7674288)
Originally Posted by double clutch
(Post 7674295)
Do they custom drill? I want es2s but would rather just get them in 5x110 than hub swap
Update
I decided to go with ESR S02 custom drilled.https://cimg9.ibsrv.net/gimg/www.cob...fa7d88eca.jpeg
Did you contact them to have them redrilled?
(Post 7685938)
Sneak peek
https://cimg1.ibsrv.net/gimg/www.cob...ade410674f.jpgPlanning to run Pirelli 235/40/18
The wheels are facing backwards....
(Post 7686024)
I've personally never liked the studded look for rims, but if you like them, it's your car!
Update
So after getting the tires mounted on the wheels attempted to mount the wheels to the car and guess what brembos do not clear in the front life sucks.https://cimg7.ibsrv.net/gimg/www.cob...2ced26bb3b.jpg
I actually like the stock rims better.
did you use a spacer?
Not sure on your budget, but I have the real wheels that these knocks off replicate. Clean brembos no problem :)
Update
I did not try using a spacer, also I went with 235 40-18 Federal 595 tires. The wheels are 18x8.5 +30. What size spacer do I need to be able to clear the brembos?
Originally Posted by tomss
(Post 7688929)
I think you need a +40 offset for them to clear brembos
(Post 7688945)
Originally Posted by Jbsmusic1
(Post 7688947)
So would running 10mm hub centric spacers cause any issues?
Fender Flares?
Has anyone installed fender flares on a cobalt ss tc sedan?
try a 5mm spacer first and see how well that works out for you. if not youll have to run extended lugs
