LSJ Shim kit?
Does anyone know where to buy the shim kit to help out with the uneven wear on the tires in the rear?
O.ô
Dumb question but uhm... Alignment? |
Originally Posted by G85 SS
(Post 7448895)
O.ô
You should be able to get them at auto parts store. Or firestone
rockauto.com
can only do it so much though before it effects the brakes. if it is that far off, you need to look for bent parts though. |
The caliper bracket needs to be shim as well
Took it to firestone they said toatl job would cost 750 because they would need to put new tires on the back because they dont want to do an alignment with slightly used tires
Originally Posted by Squints
(Post 7453258)
