Michelin PS4S
Going to be replacing my Nitto NT555 G2's with some Michelin PS4S's and wanted to see if anyone had any experience with the PS4's or Pilot Super Sports on their Cobalt?
FWIW, I really enjoyed my G2's for the first 25K miles. I've got almost 30K on them now and while they still have a decent amount of tread left, they've only lasted 2 AZ heat cycles.... ZERO traction 1st through 3rd and cornering is drastically reduced. |
In for info as I will probably be getting new tires this year
You can never go wrong with Pilot Super Sports. I have ran them on multiple cars.
Go on tire rack, they usually have some really good road test/comparisons of tires.
Pulled the trigger on some 235's. Will keep everyone posted once I get them installed.
Didn't want to wait weeks for the 235 so went with factory 225 .
So far, it's an amazing tire but it's still fresh. Makes it hard to say good or bad but, it dead hooks 1-3 :) |
Are the 235 on backorder?
I just threw them on mine. Awesome - both in when dry and in the rain. Gotta do something pretty dumb to get them loose (so far).
So far I've never had tires that would hook in 1st. Drag radials would in 2nd if they were hot but not if cold. I have even spun slicks off the line but not in 2nd. Can't believe you can hook 1st gear with those tires.
Originally Posted by Snail_SS
(Post 7693034)
(Post 7693035)
Don't you have a bigger turbo and it still dead hooks? That's outstanding.
(Post 7693041)
Seems like you sold me on them, keep us posted as you keep driving on them
I've had Pilot Super Sports in 245/40R18 on for about 3 summers now. With around 15k on them with mainly normal driving and a few launches here and there plus some spirited back road driving, I'm still at 5/32 tread on all 4. Just make sure to store them indoors during the winter if it gets below freezing as I haven't and there's a small amount of cracking happening.
as everyone else already stated, that's awesome that you can hook that well with a 300tw class tire. How aggressive is your boost ramp?
Originally Posted by 07blackg5
(Post 7695120)
Honestly though, straight line traction aside, these are the nicest tires I've ever driven on. They've completely transformed the car, in a very positive manner. Highly recommend these to anyone and everyone. |
I had 245/40/17s on 17x9 et40 wheels and they cleared, but were close. I'm just on coilovers, so they have a bit more clearance between the wheel/tire and the spring perch vs the stock struts. That being said, I know quite a few people that run 245's and are okay.
Currently on 245/45/16 on an et38 wheel |
that's a full inch bigger diameter than my 24.7", so you might rub fender liner a bit with the extra .5", depending on how low you are.
you shouldn't hit anything structural, just fender liners.
Originally Posted by HGT
(Post 7695135)
245's clear everything on turns?
Wish I felt good about 245's on a 8"rim but I'm afraid I would give up handling due to the tread width being so much wider than the rim. On a 9" that would be a different story.
And I'm still puzzled at dead hooking. I couldn't even do that on drag radials 1st gear limited to 10-15psi, on basically a factory turbo.
1 Attachment(s)
(Post 7695607)
I had 245 drag radials mounted on 7.5 wheels and you could tell a little difference. Don't think my 8" wide M52's are going to make much of a difference there. I would probably order 235's for my setup.
