Please help 05 Cobalt LS rims
HI Im a noobie. Ive done research here, very knowledgeable and really sweet rides. I have stock 15's. I would like to put 19's with a lip, what's my offset limit? I would probably have to put some lo pro tires on as well huh? no problem. What are my options to change my 4x100 lug pattern?? any adapters, etc.? Thanks guys. You rule.:confused:
http://perfectlyround.com/
HPD wheels.. they have a couple wheels that may fit your liking.. the wheels i ordered are by this company. Honestly... as far as 19's with a lip go you may be looking at something custom drilled.. becuz finding the right offset, width, bolt pattern and look it going to be a challenge... u do have options though 35 series tires is what you would need to run |
as far as changing the lug pattern.... not gonna happen... way too expensive of a conversion.. as far as wheel options there are a TON. 4x100 is a very popular pattern. Go check out tirerack.com or just about any wheel site. and you will find whatever you desire more than likely
