RIM help???????
RIM help???????
http://shopping.netsuite.com/s.nl/c....t.A/id.7840/.f
These rims would look sick on my black ss/sc but idk what size to get 18x7.5 or 18x8, also idk if they have our 5x110 bolt pattern if anyone has these or knows if they will work plz help
stock is 18x7.5 and the bolt pattern must be 5x110, stock offset is 42mm.
this web link doesn't show what the bolt pattern is...should call and find out.
at the top of the page there is a link that says "What fits?" select your vehicle and it will show you the ones that will fit
it must have a 5x110 bolt pattern to fit regardless of what size wheel you buy. 18x7.5 will obviously fit so will the 18x8, but again it must have the 5x110 bolt pattern. and you'll want to keep the offset right around 38 to 42mm. try not to go any smaller that 38mm. you could call to see if they have them in that bolt pattern or if they could special make them for ya.
Does anyone know if Size: 18x7.5 +45mm & Bolt Patterns: 4x100/4.5 will fit on an LS Cobalt? About to buy some and just want to make sure they will fit on my cobalt before I go through the hastle and it seems like you guys are the authority on cobalt FAQ's.
jcalvin1126
Oct 26, 2015 12:31 AM
DANRICKARD
Oct 1, 2015 12:08 AM
