Service Traction Control and ABS
Just over a year ago I had to get 2 new tires. I didn't have much money and couldn't find a cheap pair of 205/55/R16. However I did find a pair or 205/60/R16. I put them on and almost instantly the traction control and ABS lights came on as well as the DIC saying "Service Traction". I'm assuming that it was because 2 of the 4 tires were a different size. On friday I finally changed out the original tires and got 2 more 205/60/R16 so all the tires are the same size, but the traction light and abs light still come on. What does that mean? Should I unhook the battery and reset the system? Is it a sensor? (God I hope not!!). Or should I just give it time to reset itself? Any help would be much appreciated.
It could be wheel bearing issues. I had a bad wheel bearing and my ABS dash light was on. When I switched out my bearings, the light went out. Their are sensors built into the wheel bearing assemblies that had gone bad.
how much of a pain in the ass is that to change? or is it better to just have a mechanic do it? also yesterday the lights just went off for the whole day, then came on later in the night when i turned the car back on. it went through about 6 cycles of off and on without it turning back on.
i had the same thing you did when my front passenger wheel earing went with one additional kicker, just after fuelling up cruise control would not engage for about fifty miles. Replaced wheel bearing everything went away
importkiller
09-30-2015 07:18 PM
